Silica Listview ContextMenu - opening menu on a long post results in black screen
BUILD ID = OS VERSION (Settings > About product): Since 1.0.5 most likely (2.0.x 100%, the bug report in quickddit is from 2017)
HARDWARE (XA2, X10, X10 II, …): AFAIK non-HW specific (definitely happens on jolla1, jollaC, xperia x)
UI LANGUAGE: ALL
REGRESSION: (compared to previous public release: Yes, No, ?): No, old bug
If you open a MenuItem from a ContextMenu on a long item (release notes thread in SFOS Forum Viewer for example, but happens also in Neliapila and Quickddit (https://github.com/accumulator/Quickddit/issues/30)) instead of having the menu show up as it normally does the screen goes black (actually just the highlight of the item and the menu, as you can see that only that part is blacked if you turn sideways for example)
A rather long Item in a ListView
  1. Go to release notes thread or community news thread in sfos forum viewer and long press on the first post
  2. that’s it
Menu shows up normally and you can choose your option
Black screen and you have to play russian roulette with the menu (you can still tap there if you know where the option should be and it does work)
The bug has been there as far as I can remember, can’t find anything on TJC atm, but worth bringing this back up, maybe it’s just those three apps that are getting it wrong, but something is not right, the slowness of high-light and menu expansion when the item is almost hitting the limit is also there (even if it doesn’t go black)
Fixed in 5.0.x, at least not getting it on C2 anymore
And it’s back on J2 (for example OP in Sailfish Community News, 13 August 2026 - Jolla Phone delivery update)
I can also still reproduce this with Xperia 10 III running Sailfish 5.1.0.11. The issue has been there for quite a long time as far as I remember.
Same here wit 10III… Also before 5.1 on some entries with firum viewer.
Images showing the symptom n 5.1.0.11. Look at the last image here, the post after is visible.
Not selected:
Holding:
Selection menu displayed:
