BUILD ID = OS VERSION (Settings > About product): 3.4.0.24
HARDWARE (Jolla1, Tablet, XA2,…): Xperia X
UI LANGUAGE: English
REGRESSION: (compared to previous public release: Yes, No, ?): Don’t know
SMS registration fails on Signal 5.1.8.
Xperia X with Aliendalvik installed. No Google Play services.
Install Signal 5.1.8
Insert phone number to get a registration SMS sent
Signal does not crash
Signal crashes. The SMS arrives a few seconds later, but registration won’t proceed. When I open Signal again, I get back to the screen when I have to enter my phone number (1).
If you have access to the terminal, it would be helpful if you included output of journalctl -f when teh crash occurs to assess whether this is a problem on the SFOS side.
FWIW, earlier versions of Signal didn’t fail at this point, but I forget which version exactly.
01-13 11:40:17.768 1435 1577 D audio_hw_primary: start_output_stream: enter: stream(0x878c70)usecase(0: deep-buffer-playback) devices(0x2)
01-13 11:40:17.768 1435 1577 E audio_hw_primary: voice_extn_compress_voip_is_active: COMPRESS_VOIP_ENABLED is not defined
01-13 11:40:17.768 1435 1577 E msm8916_platform: voice_extn_compress_voip_is_active: COMPRESS_VOIP_ENABLED is not defined
01-13 11:40:17.768 1435 1577 D audio_hw_primary: select_devices: out_snd_device(4: wsa-speaker) in_snd_device(0: )
01-13 11:40:17.769 1435 1577 D hardware_info: hw_info_append_hw_type : device_name = wsa-speaker
01-13 11:40:17.769 1435 1577 D audio_hw_primary: enable_snd_device: snd_device(4: wsa-speaker)
01-13 11:40:17.776 1435 1577 W audio_hw_utils: audio_extn_utils_update_stream_app_type_cfg: App type could not be selected. Falling back to default
01-13 11:40:17.776 1435 1577 I audio_hw_primary: select_devices Selected apptype: 69936
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> send_audio_cal, acdb_id = 15, path = 0
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> send_asm_topology
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_STREAM_TOPOLOGY_ID
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> send_adm_topology
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_COMMON_TOPOLOGY_ID
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> send_audtable
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_COMMON_TABLE_SIZE
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> AUDIO_SET_AUDPROC_CAL
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> send_audvoltable
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_GAIN_DEP_STEP_TABLE
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> AUDIO_SET_AUDPROC_VOL_CAL
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> send_audstrmtable
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_STREAM_TABLE_V2
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> audstrm_cal->cal_type.cal_data.cal_size = 32
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> send_afe_topology
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AFE_TOPOLOGY_ID
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> GET_AFE_TOPOLOGY_ID for adcd_id 15, Topology Id 112fa
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> send_afe_cal
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AFE_COMMON_TABLE
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> AUDIO_SET_AFE_CAL
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> send_hw_delay : acdb_id = 15 path = 0
01-13 11:40:17.776 1435 1577 D ACDB-LOADER: ACDB -> ACDB_AVSYNC_INFO: ACDB_CMD_GET_DEVICE_PROPERTY
01-13 11:40:17.777 1435 1577 I audio_hw_utils: audio_extn_utils_send_app_type_cfg app_type 69936, acdb_dev_id 15, sample_rate 48000
01-13 11:40:17.777 1435 1577 D audio_hw_primary: enable_audio_route: apply mixer and update path: deep-buffer-playback
01-13 11:40:17.778 1435 1577 D audio_hw_primary: select_devices: done
01-13 11:40:17.872 1435 1577 D audio_hw_primary: start_output_stream: exit
01-13 11:40:18.770 10203 10203 E cutils-trace: Error opening trace file: No such file or directory (2)
01-13 11:40:18.892 15308 15308 D libEGL : loaded /vendor/lib/egl/libEGL_adreno.so
01-13 11:40:18.991 15308 15308 D libEGL : loaded /vendor/lib/egl/libGLESv1_CM_adreno.so
01-13 11:40:19.009 15308 15308 D libEGL : loaded /vendor/lib/egl/libGLESv2_adreno.so
01-13 11:40:19.055 15308 15308 I Adreno : QUALCOMM build : 26dcca9, Ibef77cadeb
01-13 11:40:19.055 15308 15308 I Adreno : Build Date : 06/10/16
01-13 11:40:19.055 15308 15308 I Adreno : OpenGL ES Shader Compiler Version: XE031.06.00.02
01-13 11:40:19.055 15308 15308 I Adreno : Local Branch : mybranch20222659
01-13 11:40:19.055 15308 15308 I Adreno : Remote Branch : quic/LA.BR.1.3.3_rb2.20
01-13 11:40:19.055 15308 15308 I Adreno : Remote Branch : NONE
01-13 11:40:19.055 15308 15308 I Adreno : Reconstruct Branch : NOTHING
01-13 11:40:22.335 1435 1577 D audio_hw_primary: out_standby: enter: stream (0x878c70) usecase(0: deep-buffer-playback)
01-13 11:40:22.631 1435 1577 D audio_hw_primary: disable_audio_route: reset and update mixer path: deep-buffer-playback
01-13 11:40:22.634 1435 1577 D hardware_info: hw_info_append_hw_type : device_name = wsa-speaker
01-13 11:40:22.634 1435 1577 D audio_hw_primary: disable_snd_device: snd_device(4: wsa-speaker)
They mostly look like messages related to audio output though, apart those at 01-13 11:40:18.770 and successive. Not sure what cutils-trace is and if I should have it on my phone. find confirms I don’t have a file with that name.
Thank you for this I will have to defer to people who know better than me, as I can’t see how or what is failing in your case. I assume that you made Signal crash and then took the logcat output.
My guess would be: You’re experiencing an effect of the general run on Signal.
They’ve stated in their Twitter feed the number of new registrations was so massive since WhatsApp announced their change of terms that at times the systems couldn’t send all the registration codes.
Hi,
I had the same behavior on my Xperia X. I solved it by pulling the SIM card and putting it into an old spare phone. I then received the SMS on the other phone and entered the code on the Xperia without problems.
Thanks! I tried that today, but the app crashes anyway, even if there is no SIM card in the phone, before I get the opportunity to enter the confirmation code.
