I just switched over to Signal on AAS as primary device (downloaded the apk from their website). But it seems incoming calls dont work as expected. When someone calls me I can here the jolla notification ringtone, but the signal call window doesnt show - meaning I dont have a way to accept or decline the call. The only way around that is knowing who is calling and then starting a call like normal which will bring up the desired call window.
Does anybody else notice that or does someone have a solution for that as long as Whisperfish does not support calls?
When you hear incomig call, swipe to events view. There you can see notification about incoming call, press it. This will open the call window. Not the prettiest, but works
I found that out shortly after typing. Thanks. I just expacted the window to pop up when there is an incoming call. c:
I found a similar issue & solution for AAS calendar alarms. Seems like AAS apps can’t bring themselves to the front - probably worth a bug report…
Off topic here, but I just linked all my other calendars to SFOS side and see them beautifully at events view. I still manage them in other places, but think calendar is pretty neat in SFOS side
