BUILD ID = OS VERSION (Settings > About product): 4.3
HARDWARE (XA2, X10, X10 II, …): XA2
UI LANGUAGE: German
I want to Share-copy & paste stuff from Android apps to Sailfish ones. Unfortunately, using the Android Share-button in the Android share function doesn’t work.
Android app
select text in Android app - e.g. taz newspaper app
share > copy text with Android function
Switch to Sfos app and try to paste
Text would be filled in in Sfos
Text is not filled into Sfos app
They’re kind of like different worlds - they don’t really interact with each other.
One workaround I’ve used is to have a file in Android home (/sdcard) that I can copy/paste into, and then access that file from SF filesystem, and copy/paste from it, etc… You could even symlink or something to make it easier.
Also, kdeConnect works between SF and Android, to a degree…
