HI,
Quick question does SFOS 4.x provides echo cancellation module for pulseaudio? Basically phone is barely usable without headphones with ext mic due to clearly audible cho, even if i’m not using loudspeaker. I was hoping that with this plugin I can improve call quality to at least bearable level.
It seems it might be not available. It doesn’t appear on pactl list modules command, nor in the list of available packages found by zypper.
