So I started running the tests, current setup is:
- Xperia 10II, build 4.5.0.19
- Using the 4G to access internet (in case that has some influence).
- Browser has 0 active tabs.
- Only open apps are settings and browser.
- Browser is still default config, no change in the about:config.
- I installed Memory watcher | OpenRepos.net — Community Repository System following @karry 's tutorial Sailfish OS and memory :: karry.cz to check my peak memory usage.
I accessed the website Visual Studio Code March 2023 which has a surprising one shot one kill effect and always kills my browser when opened. It’s my first time ever visiting this specific page.
Bellow my “journalctl -f”, i pasted the “full” log here: Framapad annuel
As you can see I open the browser (which previously crashed) at 17:09:13:
Mai 06 17:09:13 Xperia10II-DualSIM dbus-daemon[5957]: dbus-daemon[5957]: [session uid=100000 pid=5957] Activating service name='org.sailfishos.browser.ui' requested by ':1.5520' (uid=100000 pid=25032 comm="/usr/libexec/mliteremoteaction org.sailfishos.brow" label="u:r:kernel:s0")
And 4 seconds later lowmemorykiller is killing stuff:
Mai 06 17:09:19 Xperia10II-DualSIM kernel: lowmemorykiller: Killing 'am.android:mqtt' (24015), adj 905,
to free 47172kB on behalf of 'Cache2 I/O' (25167) because
cache 744468kB is below limit 745120kB for oom_score_adj 529
Mai 06 17:09:19 Xperia10II-DualSIM kernel: lowmemorykiller: Killing 'stagram.android' (23854), adj 250,
to free 153008kB on behalf of 'HwBinder:3134_1' (24676) because
cache 652904kB is below limit 652960kB for oom_score_adj 147
Mai 06 17:09:20 Xperia10II-DualSIM kernel: lowmemorykiller: Killing 'id.ext.services' (22516), adj 100,
to free 59600kB on behalf of 'Cache2 I/O' (25167) because
cache 560784kB is below limit 560800kB for oom_score_adj 58
Mai 06 17:09:20 Xperia10II-DualSIM kernel: lowmemorykiller: Killing 'stagram.android' (25321), adj 0,
to free 46920kB on behalf of 'pool-tracker-mi' (25022) because
cache 464416kB is below limit 468640kB for oom_score_adj 0
Mai 06 17:09:20 Xperia10II-DualSIM kernel: lowmemorykiller: Killing 'maliit-server' (20203), adj 0,
to free 54364kB on behalf of 'systemd-journal' (632) because
cache 457108kB is below limit 468640kB for oom_score_adj 0
Mai 06 17:09:20 Xperia10II-DualSIM kernel: lowmemorykiller: Killing 'invoker' (25035), adj 0,
to free 2400kB on behalf of 'VideoDecMsgThre' (25313) because
And finally the browser…
Mai 06 17:09:20 Xperia10II-DualSIM kernel: lowmemorykiller: Killing 'sailfish-browse' (22258), adj 0,
to free 384508kB on behalf of 'HwBinder:3134_5' (6054) because
cache 456492kB is below limit 468640kB for oom_score_adj 0
At 19:09:07 (so before re-opening the browser after it crashed), my memory was shared between:
Memory at 2023-05-06T17:09:07.194
Memory details: 3.5 GiB total, 48.9 MiB free, 138.5 MiB buffers, 838.0 MiB cached (including 11.2 MiB shmem (tmpfs)), 0 B swap cache
Kernel: 509.8 MiB SLAB (117.7 MiB reclaimable),
~ 1.5 GiB other kernel memory? It means: total - anonymous process - slab - free - buffers - cached - swap cache
Swap: 1024.0 MiB total, 340.2 MiB free (33%)
Available: 1.2 GiB (35%) estimated by kernel
1.1 GiB (32%) computed. It means: free + buffers + (cached - Shmem) + swap cache + slab reclaimable
Processes memory (smaps Pss):
PID process size (% of total) [oom_adj, oom_score, oom_score_adj]
22258 booster [browse 21.6 MiB (1%) [-1000, 0, 0]
7451 tracker-miner-f 15.8 MiB (0%) [-750, 0, 0]
20290 memory-record 14.2 MiB (0%) [-1000, 0, 0]
25008 tracker-extract 9.2 MiB (0%) [-750, 0, 0]
6293 pulseaudio 7.7 MiB (0%) [-750, 0, 0]
6035 xt9-server 6.5 MiB (0%) [-750, 0, 0]
5902 systemd 2.5 MiB (0%) [-750, 0, 0]
5957 dbus-daemon 1.7 MiB (0%) [-750, 0, 0]
6408 dconf-service 1.6 MiB (0%) [-750, 0, 0]
6041 ngfd 1.4 MiB (0%) [-750, 0, 0]
14141 alienkeyboardse 901.0 KiB (0%) [-750, 0, 0]
6687 0 840.0 KiB (0%) [-1000, 0, 0]
14105 alienaudioservi 705.0 KiB (0%) [-750, 0, 0]
7048 booster-browser 417.0 KiB (0%) [-1000, 0, 0]
22545 invoker 388.0 KiB (0%) [-750, 0, 0]
21999 bash 339.0 KiB (0%) [-1000, 0, 0]
15270 bash 332.0 KiB (0%) [-1000, 0, 0]
21727 bash 322.0 KiB (0%) [-1000, 0, 0]
21879 bash 321.0 KiB (0%) [-1000, 0, 0]
6625 mpris-proxy 292.0 KiB (0%) [-750, 0, 0]
6031 profiled 228.0 KiB (0%) [-750, 0, 0]
21816 grep 217.0 KiB (0%) [-1000, 0, 0]
6493 audiosystem-pas 76.0 KiB (0%) [-750, 0, 0]
5954 ohm-session-age 33.0 KiB (0%) [-750, 0, 0]
14174 invoker 26.0 KiB (0%) [-750, 0, 0]
6688 invoker 25.0 KiB (0%) [-750, 0, 0]
6635 invoker 25.0 KiB (0%) [-250, 0, 0]
6220 invoker 24.0 KiB (0%) [-750, 0, 0]
14249 invoker 24.0 KiB (0%) [-750, 0, 0]
6028 invoker 24.0 KiB (0%) [-750, 0, 0]
others 295.0 KiB (0%)
sum 88.1 MiB (2%)
At 17:09:17 (while lowmemorykiller was slaughtering) it was:
Memory at 2023-05-06T17:09:17.192
Memory details: 3.5 GiB total, 18.5 MiB free, 138.9 MiB buffers, 837.1 MiB cached (including 12.1 MiB shmem (tmpfs)), 0 B swap cache
Kernel: 510.0 MiB SLAB (117.8 MiB reclaimable),
~ 1.4 GiB other kernel memory? It means: total - anonymous process - slab - free - buffers - cached - swap cache
Swap: 1024.0 MiB total, 340.5 MiB free (33%)
Available: 1.1 GiB (33%) estimated by kernel
1.1 GiB (31%) computed. It means: free + buffers + (cached - Shmem) + swap cache + slab reclaimable
22258 booster [browse 250.1 MiB (7%)
25037 booster [browse 20.8 MiB (1%) [-1000, 0, 0]
7451 tracker-miner-f 15.9 MiB (0%) [-750, 0, 0]
20290 memory-record 14.3 MiB (0%) [-1000, 0, 0]
5902 systemd 2.6 MiB (0%) [-750, 0, 0]
14141 alienkeyboardse 897.0 KiB (0%) [-750, 0, 0]
6687 0 845.0 KiB (0%) [-1000, 0, 0]
14105 alienaudioservi 702.0 KiB (0%) [-750, 0, 0]
25035 invoker 401.0 KiB (0%)
22545 invoker 366.0 KiB (0%) [-750, 0, 0]
7048 booster-browser 348.0 KiB (0%) [-1000, 0, 0]
6034 invoker 24.0 KiB (0%) [-750, 0, 0]
6934 invoker 24.0 KiB (0%) [-500, 0, 0]
others 316.0 KiB (0%)
sum 328.5 MiB (9%)
And at 17:09:22 (after the browser crashed) :
Memory at 2023-05-06T17:09:22.195
Memory details: 3.5 GiB total, 237.5 MiB free, 90.9 MiB buffers, 412.4 MiB cached (including 10.3 MiB shmem (tmpfs)), 0 B swap cache
Kernel: 497.9 MiB SLAB (106.9 MiB reclaimable),
~ 1.9 GiB other kernel memory? It means: total - anonymous process - slab - free - buffers - cached - swap cache
Swap: 1024.0 MiB total, 330.7 MiB free (32%)
Available: 882.0 MiB (25%) estimated by kernel
837.4 MiB (24%) computed. It means: free + buffers + (cached - Shmem) + swap cache + slab reclaimable
25037 booster [browse 24.6 MiB (1%) [-1000, 0, 0]
7451 tracker-miner-f 15.6 MiB (0%) [-750, 0, 0]
20290 memory-record 14.5 MiB (0%) [-1000, 0, 0]
25341 tracker-extract 9.5 MiB (0%) [-750, 0, 0]
6293 pulseaudio 7.6 MiB (0%) [-750, 0, 0]
6035 xt9-server 6.1 MiB (0%) [-750, 0, 0]
6687 0 844.0 KiB (0%) [-1000, 0, 0]
14141 alienkeyboardse 832.0 KiB (0%) [-750, 0, 0]
14105 alienaudioservi 706.0 KiB (0%) [-750, 0, 0]
7048 booster-browser 423.0 KiB (0%) [-1000, 0, 0]
15270 bash 322.0 KiB (0%) [-1000, 0, 0]
21727 bash 317.0 KiB (0%) [-1000, 0, 0]
21999 bash 317.0 KiB (0%) [-1000, 0, 0]
21879 bash 314.0 KiB (0%) [-1000, 0, 0]
21816 grep 209.0 KiB (0%) [-1000, 0, 0]
6031 profiled 208.0 KiB (0%) [-750, 0, 0]
6635 invoker 26.0 KiB (0%) [-250, 0, 0]
6037 invoker 24.0 KiB (0%) [-750, 0, 0]
6616 invoker 24.0 KiB (0%) [-750, 0, 0]
others 271.0 KiB (0%)
sum 90.3 MiB (3%)
That’s the first information I found, I wonder what steps can I do next so we can get further on this topic ?
but unfortunately Chiang Mai tourism hit by smog.
