I was trying to build calligra (for calligraconverter) for aarch64, using the new EA build targets, but i’m getting:
attah@obsidian ~/repos/calligra $ sfdk config target=SailfishOS-4.1.0.23EA-aarch64
[D] SOFT ASSERT: "!path.isEmpty()" in file ../../../../sailfish-qtcreator/src/libs/sfdk/vboxvirtualmachine.cpp, line 123
attah@obsidian ~/repos/calligra $ sfdk build
The following 40 NEW packages are going to be installed:
bison boost-atomic boost-chrono boost-container boost-date-time boost-devel boost-exception boost-filesystem boost-graph boost-iostreams boost-locale boost-log boost-math boost-program-options boost-random
boost-regex boost-serialization boost-signals boost-stacktrace boost-test boost-timer boost-type_erasure boost-wave extra-cmake-modules flex gettext gettext-devel gettext-libs icu libeigen3-devel libgomp
libicu-devel libkf5archive-devel libtextstyle m4 qt5-qtprintsupport-devel qt5-qtscript qt5-qtscript-devel qt5-qttest-devel shared-mime-info-devel
40 new packages to install.
Overall download size: 0 B. Already cached: 17.9 MiB. After the operation, additional 17.9 MiB will be used.
Continue? [y/n/v/...? shows all options] (y): y
Installation of boost-atomic-1.66.0+git2-1.2.4.jolla.aarch64 failed:
Error: Subprocess failed. Error: RPM failed: error: db4 error(-30971) from dbenv->open: DB_VERSION_MISMATCH: Database environment version mismatch
error: cannot open Packages index using db4 - (-30971)
error: cannot open Packages database in /var/lib/rpm
Abort, retry, ignore? [a/r/i] (a): a
Problem occurred during or after installation or removal of packages:
Installation has been aborted as directed.
Turs out it is the same for armv7hl too. I tried a fulll reinstall of the SDK, but no change. I have both current and EA targets installed.
