For some time, AFAIR with 4.0.x update, Settings app started to lag at start. I suppose some additional installable component hangs on initialization. It lasts for 6-7 seconds and I can’t do anything (UI hangs). After that period everything works perfectly. Logs shows just bunch of “file:///usr/lib/qt5/qml/Sailfish/Lipstick/LauncherIcon.qml:30:41: Unable to assign [undefined] to bool” errors.
My question is. does anybody know how to check what process could cause this issue? What comes to my mind to remove/install one component by one but it is hard to determine which packages does what…
Doesn’t matter for me. Eg. bluetooth settings started from top menu also does not respond for some time. But touch events are queued and actions executes after lag ends.
Also not the issue for me. The delay is about 2 seconds. It doesn’t matter via which way I enter the settings (app icon, gps settingspulldown, bluetooth settings pulldown).
@pemek: You mention that you’re seeing the error above in your logs. Would you mind please running the following command on your device and pasting the output here?
cat -n /usr/lib64/qt5/qml/Sailfish/Lipstick/LauncherIcon.qml | sed -n -e 20,40p
I tried to follow this up, but the error is showing on line 30 of the LauncherIcon.qml file, which with the default installation only has 29 lines. So it would be good to know what’s happening in this file on your device, in case it sheds some light on what’s going wrong.
Just for info, the libpng warning is usually caused by an image/icon that has been processed through photoshop (maybe other editors, but I recognise this from photoshop), it should not cause any actual errors for the app though but does throw up a warning in console.
Whenever I create or edit in photoshop, there are options for turning this color profile off when saving your image. I make sure to untick it purely so I don’t have to see pointless errors in console.
