Setting to level the microphone when calling
Is it possible to implement a setting to level the microphone when calling?
As a workaround, you could try to set the level of the microphone on the command line, see Audio quality during phone calls on Xperia 10 II - #8 by rdomschk
I was able to select a beta version in the phone settings after an update. This improved the connections. At least my call partners no longer complained. This option is now no longer available in the settings. Unfortunately, I was unable to keep track of the history for personal reasons.
I also use headsets very often since then and this has also solved the problem.
Thank you for your offer of help.
Translated with DeepL.com (free version)
