I am pretty new to SFOS, and I love it.
Question for gurus.
Which application to use for serial via usb console connection to network devices?
How to find necessary parameters to make a connection.
I found that I have a screen application, which I usually using for serial terminal connection to switches from the MacOS terminal app.
Are there any kind of application similar to minicom?
some more explanation.
in windows, we can use putty and choose COM port and run serial console connection. In Linux Ubuntu and Fedora, I prefer to use minicom. what are you guys using for serial connection to devices?
thank you.
I would be very interrested too.
I have a serial antenna that I usb plug on a PC to command a motion control.
I could plug it on the phone and command the machine with accelerometers.
I think it is a similar case as I also use minicom on a tty to send characters to it.
It is like an FTDI cable IIRC.
