It would be nice to separately enable/disable vibration feedback for different system components. If under Settings/Sounds and feedback/Feedback/Touch screen vibration toggle is disabled it disables e.g. both keyboard and pull-down menu haptics.
I think it would be beneficial to separate keyboard vibration from overall system vibrations.
I personally never use keyboard haptics, while I’m typing I’m looking at what I do and haptics don’t really give any extra information to me.
On the other hand, pull menus only feel easy and convenient to use if haptics is enabled.
