Sensorfwd CPU usage
REPRODUCIBILITY: Always
OS VERSION: 5.2.0.16
HARDWARE: Jolla Phone 2026
UI LANGUAGE: Russian
REGRESSION: No
The sensorfwd process constantly consumes about 0.1% of the CPU.
None.
  1. Open the Terminal application and run top.
CPU usage on an idle phone approximates zero.
Various processes can be seen running at all times, including /usr/sbin/sensorfwd and /vendor/bin/hw/android.hardware.sensors-service.multihal.
After enabling debug logging as documented in GitHub - sailfishos/sensorfw · GitHub, some of the log output is
авг 10 11:18:17 JollaPhone2026 sensorfwd[2134]: sensorfw: QUEUE HYBRIS EVE LIGHT
авг 10 11:18:17 JollaPhone2026 sensorfwd[2134]: sensorfw: HYBRIS EVE LIGHT
авг 10 11:18:17 JollaPhone2026 sensorfwd[2134]: sensorfw: QUEUE HYBRIS EVE ACCELEROMETER
авг 10 11:18:17 JollaPhone2026 sensorfwd[2134]: sensorfw: HYBRIS EVE ACCELEROMETER
авг 10 11:18:39 JollaPhone2026 systemd-journald[854]: Suppressed 750 messages from sensorfwd.service
авг 10 11:18:39 JollaPhone2026 sensorfwd[2134]: sensorfw: QUEUE HYBRIS EVE ACCELEROMETER
авг 10 11:18:39 JollaPhone2026 sensorfwd[2134]: sensorfw: HYBRIS EVE ACCELEROMETER
авг 10 11:18:39 JollaPhone2026 sensorfwd[2134]: sensorfw: QUEUE HYBRIS EVE LIGHT
авг 10 11:18:39 JollaPhone2026 sensorfwd[2134]: sensorfw: HYBRIS EVE LIGHT
This could explain some of the CPU activity, but the CPU usage persists even if the phone lies flat on a surface.
There is also another thread: [5.2] Jolla Phone 2026 mtkfusionrild CPU usage. The sensorfwd part is probably unrelated.
The system always has a load average of around 12.
I’d argue that 0.1 “approximates zero”. What is the actual problem this causes - or why is it so bad?
