As title suggests, I’d find it good to have ability to select automatic VPN connection to connect, if clicked on top menu. Currently, when you have more than 1 connections configured it opens settings page, which can be found annoying when using one VPN very often (as I do). User should be able to configure default one, or select “recent” (the last one active).
If you leave VPN on when turning Mobile Data (or also WLAN) off, it should automatically reconnect with the last selected VPN when you reconnect with mobile data or WLAN next time.
Terminology: Do you mean Top menu? Pulley menus are the ones with rows and haptic feedback.
Now I’m confused, @attah . I think @WunderWungiel means the top menu, where the lock, the ambiences, some settings (if activated), the brightness (maybe also volume) control and some other settings (if activated) from the main Settings menu are.
But what is now pulley menu? There are also rows on the top menu and haptic feedback comes only if vibrator is on and never if turned off in its settings.
How do you not know this?
Top menu: ambiances, toggle buttons brightness slider etc.
Pulley menu: Line-by-line text choices, in apps.
I was not exact in my wording, I meant top menu. I’m sorry.
Sorry, I meant top menu
