I just bought a second hand Jolla Phone with the latest update and dealer has correctly done a reset. I started the phone and completed the wizard, I didn’t set a security code and once I finished the process, followed the tutorial I had to enter the old security code…
So, I’m just curious if it’s an old bug which is resolved with Sailfish 4.4.0.58. If anyone with a spare device can test, it could be nice.
That is quite interesting. I never could do a factory reset without the correct device lock code. It wasn’t possible for me to enter the recovery mode. But it’s quite sime year’s ago. So maybe things have changed.
This means that I misspoke. In my case, the phone has been reset (via Settings). Before the reset, there was a security code.
Once I started the phone after the reset, I declined the possibility to insert a new security code. After I followed all tutorials and wanted to use it, I had to insert a security code. The old one.
Just tested with someone and actually devices are now automatically encrypted. There is no more ability to skip this part and user will insert pin inserted to encrypt his device.
