Your guess is correct, so I suspect this is not really needed, but here’s the debug output anyway:
Debug output
“charset-configured”: {
“tag”: 71,
“value”: “utf-8”
“charset-supported”: {
“tag”: 71,
“value”: [
“utf-8”
“color-supported”: {
“tag”: 34,
“value”: true
“compression-supported”: {
“tag”: 68,
“value”: [
“none”,
“gzip”
“copies-default”: {
“tag”: 33,
“value”: 1
“copies-supported”: {
“tag”: 51,
“value”: {
“high”: 99,
“low”: 1
“document-format-default”: {
“tag”: 73,
“value”: “application/octet-stream”
“document-format-preferred”: {
“tag”: 73,
“value”: “image/urf”
“document-format-supported”: {
“tag”: 73,
“value”: [
“application/octet-stream”,
“image/urf”,
“image/jpeg”,
“image/pwg-raster”
“document-format-varying-attributes”: {
“tag”: 68,
“value”: “copies”
“finishings-default”: {
“tag”: 35,
“value”: 3
“finishings-supported”: {
“tag”: 35,
“value”: [
3
“generated-natural-language-supported”: {
“tag”: 72,
“value”: [
“en”,
“fr”,
“de”,
“es”,
“pt”,
“it”,
“nl”,
“no”,
“sv”,
“fi”,
“da”,
“ru”,
“cs”,
“hu”,
“pl”,
“bg”,
“ro”,
“sk”,
“sl”,
“hr”,
“tr”,
“id”
“identify-actions-default”: {
“tag”: 68,
“value”: [
“flash”,
“sound”
“identify-actions-supported”: {
“tag”: 68,
“value”: [
“flash”,
“sound”
“ipp-features-supported”: {
“tag”: 68,
“value”: [
“airprint-1.7”,
“wfds-print-1.0”
“ipp-versions-supported”: {
“tag”: 68,
“value”: [
“1.0”,
“1.1”,
“2.0”
“job-creation-attributes-supported”: {
“tag”: 68,
“value”: [
“copies”,
“finishings”,
“ipp-attribute-fidelity”,
“job-name”,
“media”,
“media-col”,
“orientation-requested”,
“output-bin”,
“output-mode”,
“print-quality”,
“printer-resolution”,
“requesting-user-name”,
“sides”,
“print-color-mode”
“job-impressions-supported”: {
“tag”: 51,
“value”: {
“high”: 999,
“low”: 1
“job-password-encryption-supported”: {
“tag”: 68,
“value”: [
“none”
“job-password-length-supported”: {
“tag”: 51,
“value”: {
“high”: 4,
“low”: 4
“job-password-repertoire-configured”: {
“tag”: 68,
“value”: “iana_us-ascii_digits”
“job-password-repertoire-supported”: {
“tag”: 68,
“value”: [
“job-password-supported”: {
“tag”: 33,
“value”: [
4
“jpeg-features-supported”: {
“tag”: 68,
“value”: [
“none”
“jpeg-k-octets-supported”: {
“tag”: 51,
“value”: {
“high”: 16384,
“low”: 0
“jpeg-x-dimension-supported”: {
“tag”: 51,
“value”: {
“high”: 15000,
“low”: 0
“jpeg-y-dimension-supported”: {
“tag”: 51,
“value”: {
“high”: 15000,
“low”: 1
“landscape-orientation-requested-preferred”: {
“tag”: 35,
“value”: 5
“marker-colors”: {
“tag”: 54,
“value”: [
“marker-high-levels”: {
“tag”: 33,
“value”: [
100,
100,
100,
100
“marker-levels”: {
“tag”: 33,
“value”: [
90,
100,
100,
100
“marker-low-levels”: {
“tag”: 33,
“value”: [
10,
10,
10,
10
“marker-names”: {
“tag”: 54,
“value”: [
“marker-types”: {
“tag”: 68,
“value”: [
“toner”,
“toner”,
“toner”,
“toner”
“media-bottom-margin-supported”: {
“tag”: 33,
“value”: [
432
“media-col-default”: {
“tag”: 52,
“value”: {
“media-auto-dimension”: {
“tag”: 34,
“value”: false
“media-bottom-margin”: {
“tag”: 33,
“value”: 432
“media-left-margin”: {
“tag”: 33,
“value”: 432
“media-right-margin”: {
“tag”: 33,
“value”: 432
“media-size”: {
“tag”: 52,
“value”: {
“x-dimension”: {
“tag”: 33,
“value”: 21000
“y-dimension”: {
“tag”: 33,
“value”: 29700
“media-source”: {
“tag”: 68,
“value”: “auto”
“media-source-properties”: {
“tag”: 52,
“value”: {
“media-source-feed-direction”: {
“tag”: 68,
“value”: “short-edge-first”
“media-source-feed-orientation”: {
“tag”: 35,
“value”: 3
“media-top-margin”: {
“tag”: 33,
“value”: 432
“media-type”: {
“tag”: 68,
“value”: “stationery”
“media-col-ready”: {
“tag”: 52,
“value”: {
“tag”: 34,
“value”: false
“tag”: 33,
“value”: 432
“tag”: 33,
“value”: 432
“tag”: 33,
“value”: 432
“media-size”: {
“tag”: 52,
“value”: {
“x-dimension”: {
“tag”: 33,
“value”: 21000
“y-dimension”: {
“tag”: 33,
“value”: 29700
“media-source”: {
“tag”: 68,
“value”: “tray-1”
“tag”: 52,
“value”: {
“tag”: 68,
“tag”: 35,
“value”: 3
“tag”: 33,
“value”: 432
“media-col-supported”: {
“tag”: 68,
“value”: [
“media-type”,
“media-size”,
“media-top-margin”,
“media-left-margin”,
“media-right-margin”,
“media-bottom-margin”,
“media-source”,
“media-auto-dimension”,
“media-source-propaties”
“media-default”: {
“tag”: 68,
“value”: “iso_a4_210x297mm”
“media-left-margin-supported”: {
“tag”: 33,
“value”: [
432
“media-ready”: {
“tag”: 68,
“media-right-margin-supported”: {
“tag”: 33,
“value”: [
432
“media-size-supported”: {
“tag”: 52,
“value”: [
“x-dimension”: {
“tag”: 33,
“value”: 21000
“y-dimension”: {
“tag”: 33,
“value”: 29700
“x-dimension”: {
“tag”: 33,
“value”: 21590
“y-dimension”: {
“tag”: 33,
“value”: 27940
“x-dimension”: {
“tag”: 33,
“value”: 21590
“y-dimension”: {
“tag”: 33,
“value”: 35560
“x-dimension”: {
“tag”: 33,
“value”: 18415
“y-dimension”: {
“tag”: 33,
“value”: 26670
“x-dimension”: {
“tag”: 33,
“value”: 14800
“y-dimension”: {
“tag”: 33,
“value”: 21000
“x-dimension”: {
“tag”: 33,
“value”: 10500
“y-dimension”: {
“tag”: 33,
“value”: 14800
“x-dimension”: {
“tag”: 33,
“value”: 17600
“y-dimension”: {
“tag”: 33,
“value”: 25000
“x-dimension”: {
“tag”: 33,
“value”: 10477
“y-dimension”: {
“tag”: 33,
“value”: 24130
“x-dimension”: {
“tag”: 33,
“value”: 11000
“y-dimension”: {
“tag”: 33,
“value”: 22000
“x-dimension”: {
“tag”: 33,
“value”: 16200
“y-dimension”: {
“tag”: 33,
“value”: 22900
“x-dimension”: {
“tag”: 33,
“value”: 9842
“y-dimension”: {
“tag”: 33,
“value”: 19050
“x-dimension”: {
“tag”: 33,
“value”: 7620
“y-dimension”: {
“tag”: 33,
“value”: 12700
“x-dimension”: {
“tag”: 33,
“value”: 21590
“y-dimension”: {
“tag”: 33,
“value”: 33020
“x-dimension”: {
“tag”: 33,
“value”: 21590
“y-dimension”: {
“tag”: 33,
“value”: 34036
“x-dimension”: {
“tag”: 33,
“value”: 21500
“y-dimension”: {
“tag”: 33,
“value”: 34500
“x-dimension”: {
“tag”: 51,
“value”: {
“high”: 21590,
“low”: 7620
“y-dimension”: {
“tag”: 51,
“value”: {
“high”: 35560,
“low”: 12700
“media-source-supported”: {
“tag”: 68,
“value”: [
“auto”,
“manual”,
“tray-1”
“media-supported”: {
“tag”: 68,
“value”: [
“iso_a4_210x297mm”,
“na_letter_8.5x11in”,
“na_legal_8.5x14in”,
“na_executive_7.25x10.5in”,
“iso_a5_148x210mm”,
“iso_a6_105x148mm”,
“iso_b5_176x250mm”,
“na_number-10_4.125x9.5in”,
“iso_dl_110x220mm”,
“iso_c5_162x229mm”,
“na_monarch_3.875x7.5in”,
“na_index-3x5_3x5in”,
“na_foolscap_8.5x13in”,
“na_oficio_8.5x13.4in”,
“om_india-legal_215x345mm”,
“custom_min_76.2x127mm”,
“custom_max_215.9x355.6mm”
“media-top-margin-supported”: {
“tag”: 33,
“value”: [
432
“media-type-supported”: {
“tag”: 68,
“value”: [
“stationery”,
“stationery-lightweight”,
“stationery-heavyweight”,
“envelope”,
“envelope-heavyweight”,
“envelope-lightweight”,
“labels”,
“photographic-glossy”,
“stationery-bond”,
“com.brother.thicker”,
“com.brother.recycled”
“mopria-certified”: {
“tag”: 65,
“value”: “1.3”
“multiple-document-jobs-supported”: {
“tag”: 34,
“value”: false
“multiple-operation-time-out”: {
“tag”: 33,
“value”: 150
“multiple-operation-time-out-action”: {
“tag”: 68,
“value”: “abort-job”
“natural-language-configured”: {
“tag”: 72,
“value”: “fi”
“operations-supported”: {
“tag”: 35,
“value”: [
2,
4,
5,
6,
8,
9,
10,
11,
59,
60
“orientation-requested-default”: {
“tag”: 35,
“value”: 3
“orientation-requested-supported”: {
“tag”: 35,
“value”: [
3,
4
“output-bin-default”: {
“tag”: 68,
“value”: “face-down”
“output-bin-supported”: {
“tag”: 68,
“value”: [
“face-down”
“output-mode-default”: {
“tag”: 68,
“value”: “color”
“output-mode-supported”: {
“tag”: 68,
“value”: [
“color”,
“auto”,
“auto-monochrome”,
“monochrome”
“pages-per-minute”: {
“tag”: 33,
“value”: 18
“pages-per-minute-color”: {
“tag”: 33,
“value”: 18
“pdf-versions-supported”: {
“tag”: 68,
“value”: [
“none”
“pdl-override-supported”: {
“tag”: 68,
“value”: [
“attempted”
“print-color-mode-default”: {
“tag”: 68,
“value”: “color”
“print-color-mode-supported”: {
“tag”: 68,
“value”: [
“auto”,
“color”,
“monochrome”,
“auto-monochrome”
“print-content-optimize-default”: {
“tag”: 68,
“value”: “auto”
“print-content-optimize-supported”: {
“tag”: 68,
“value”: [
“auto”
“print-quality-default”: {
“tag”: 35,
“value”: 4
“print-quality-supported”: {
“tag”: 35,
“value”: [
4
“print-scaling-default”: {
“tag”: 68,
“value”: “auto”
“print-scaling-supported”: {
“tag”: 68,
“value”: [
“auto”,
“auto-fit”,
“fill”,
“fit”,
“none”
“print_wfds”: {
“tag”: 65,
“value”: “T”
“printer-alert”: {
“tag”: 48,
“value”: “code=other”
“printer-alert-description”: {
“tag”: 53,
“value”: “”
“printer-config-change-date-time”: {
“tag”: 49,
“value”: “2020-09-12T10:31:56Z”
“printer-config-change-time”: {
“tag”: 33,
“value”: 1
“printer-current-time”: {
“tag”: 49,
“value”: “2020-09-23T06:10:20Z”
“printer-device-id”: {
“tag”: 53,
“value”: “”
“printer-dns-sd-name”: {
“tag”: 66,
“value”: “Brother DCP-L3550CDW series”
“printer-firmware-name”: {
“tag”: 66,
“value”: [
“MAIN”,
“SUB1”,
“SUB5”
“printer-firmware-string-version”: {
“tag”: 65,
“value”: [
“S2007270936:80F3”,
“1.59”,
“1.00”
“printer-firmware-version”: {
“tag”: 48,
“value”: [
“S2007270936:80F3”,
“1.59”,
“1.00”
“printer-geo-location”: {
“tag”: 18,
“value”: “”
“printer-get-attributes-supported”: {
“tag”: 68,
“value”: [
“document-format”
“printer-icons”: {
“tag”: 69,
“value”: [
“http://192.168.0.128/ipp/printer-icons-128.png”,
“http://192.168.0.128/ipp/printer-icons-512.png”
“printer-info”: {
“tag”: 53,
“value”: “”
“printer-input-tray”: {
“tag”: 48,
“value”: [
“type=other;mediafeed=296926;mediaxfeed=209973;maxcapacity=250;level=-3;status=0;name=AUTO;index=1;dimunit=micrometers;unit=sheets;medianame=THIN;mediaweight=-2;mediatype=Unknown;mediacolor=Unknown;”,
“type=sheetFeedManual;mediafeed=-2;mediaxfeed=-2;maxcapacity=1;level=-3;status=0;name=MANUAL TRAY;index=2;dimunit=micrometers;unit=sheets;medianame=THIN;mediaweight=-2;mediatype=Unknown;mediacolor=Unknown;”,
“type=sheetFeedAutoNonRemovableTray;mediafeed=296926;mediaxfeed=209973;maxcapacity=250;level=-3;status=0;name=TRAY1;index=3;dimunit=micrometers;unit=sheets;medianame=REGULAR;mediaweight=-2;mediatype=Unknown;mediacolor=Unknown;”
“printer-is-accepting-jobs”: {
“tag”: 34,
“value”: true
“printer-kind”: {
“tag”: 68,
“value”: [
“document”,
“envelope”,
“label”,
“postcard”
“printer-location”: {
“tag”: 65,
“value”: “ty�huone”
“printer-make-and-model”: {
“tag”: 53,
“value”: “”
“printer-mandatory-job-attributes”: {
“tag”: 68,
“value”: [
“attributes-charset”,
“attributes-natural-language”,
“printer-uri”
“printer-more-info”: {
“tag”: 69,
“value”: “http://192.168.0.128/net/net/airprint.html”
“printer-name”: {
“tag”: 66,
“value”: “BRN3C2AF4E03AEB”
“printer-organization”: {
“tag”: 65,
“value”: “”
“printer-organizational-unit”: {
“tag”: 65,
“value”: “”
“printer-output-tray”: {
“tag”: 48,
“value”: “type=unRemovableBin;maxcapacity=-2;remaining=-2;status=0;name=face-down;index=1;unit=sheets;stackingorder=firstToLast;pagedelivery=notPresent;offsetstacking=notPresent;”
“printer-resolution-default”: {
“tag”: 50,
“value”: {
“units”: 3,
“x”: 600,
“y”: 600
“printer-resolution-supported”: {
“tag”: 50,
“value”: [
“units”: 3,
“x”: 600,
“y”: 600
“printer-state”: {
“tag”: 35,
“value”: 3
“printer-state-change-date-time”: {
“tag”: 49,
“value”: “2020-09-18T16:42:07Z”
“printer-state-change-time”: {
“tag”: 33,
“value”: 69393
“printer-state-reasons”: {
“tag”: 68,
“value”: “none”
“printer-strings-languages-supported”: {
“tag”: 72,
“value”: [
“en”,
“fr”,
“de”,
“es”,
“pt”,
“it”,
“nl”,
“nb”,
“sv”,
“fi”,
“da”,
“ru”,
“cs”,
“hu”,
“pl”,
“ro”,
“sk”,
“hr”,
“tr”,
“id”
“printer-strings-uri”: {
“tag”: 69,
“value”: “http://192.168.0.128/ipp/strings/dict/en.txt”
“printer-supply-info-uri”: {
“tag”: 69,
“value”: “http://192.168.0.128/general/status.html”
“printer-up-time”: {
“tag”: 33,
“value”: 107580
“printer-uri-supported”: {
“tag”: 69,
“value”: [
“ipp://192.168.0.128/ipp/print”
“printer-uuid”: {
“tag”: 69,
“value”: “urn:uuid:e3248000-80ce-11db-8000-3c2af4e03aeb”
“pwg-raster-document-resolution-supported”: {
“tag”: 50,
“value”: [
“units”: 3,
“x”: 600,
“y”: 600
“pwg-raster-document-sheet-back”: {
“tag”: 68,
“value”: “rotated”
“pwg-raster-document-type-supported”: {
“tag”: 68,
“value”: [
“sgray_8”,
“srgb_8”
“queued-job-count”: {
“tag”: 33,
“value”: 0
“sides-default”: {
“tag”: 68,
“value”: “two-sided-long-edge”
“sides-supported”: {
“tag”: 68,
“value”: [
“one-sided”,
“two-sided-long-edge”,
“two-sided-short-edge”
“urf-supported”: {
“tag”: 68,
“value”: [
“SRGB24”,
“W8”,
“CP1”,
“IS4-1”,
“MT1-3-4-5-8-11”,
“OB10”,
“PQ4”,
“RS600”,
“V1.4”,
“DM1”
“uri-authentication-supported”: {
“tag”: 68,
“value”: [
“none”
“uri-security-supported”: {
“tag”: 68,
“value”: [
“none”
“which-jobs-supported”: {
“tag”: 68,
“value”: [
“completed”,
“not_completed”
Plus you have logs to improve the app.
