SDK sometimes creates files with 000 permissions
REPRODUCIBILITY: Occasionally
OS VERSION: 4.5.0.18
HARDWARE: SDK
UI LANGUAGE: NA
REGRESSION: Don’t know
Once in a while, result of compilation can lead to files with 000 permissions. As a result, this leads to a failure in compilation at later stages.
Get latest SFOS target and tooling. Add following repositories to compile:
 - adaptation-common ... https://releases.jolla.com/releases/4.5.0.18/jolla-hw/adaptation-common/aarch64/
 - apps              ... https://releases.jolla.com/jolla-apps/4.5.0.18/aarch64/
 - customer-jolla    ... https://releases.jolla.com/features/4.5.0.18/customers/jolla/aarch64/
 - hotfixes          ... https://releases.jolla.com/releases/4.5.0.18/hotfixes/aarch64/
 - jolla             ... https://releases.jolla.com/releases/4.5.0.18/jolla/aarch64/
 - sdk               ... https://releases.jolla.com/releases/4.5.0.18/sdk/aarch64/
Enabled repositories (user):
 - qt515  ... https://repo.sailfishos.org/obs/home:/rinigus:/qt515:/packaging/sailfish_latest_aarch64/
  1. Clone repository GitHub - sailfishos-chum/qtgraphicaleffects
  2. Checkout commit f19ed1d0bf34e615bb193e179adb2f74cad4fefc (later commits have the issue “fixed” by running chmod in directory - doesn’t always work)
  3. try to build with mb2 -t devel-aarch64 build .
Package builds
Fails at stage
/opt/qt5/bin/qmake -install qinstall /home/rinigus/qt/qtgraphicaleffects/upstream/src/effects/private/GaussianMaskedBlur.qml /home/rinigus/qt/qtgraphicaleffects/installroot/opt/qt5/lib64/qt5/qml/QtGraphicalEffects/private/GaussianMaskedBlur.qml
/opt/qt5/bin/qmake -install qinstall /home/rinigus/qt/qtgraphicaleffects/upstream/qml/QtGraphicalEffects/private/DropShadowBase.qmlc /home/rinigus/qt/qtgraphicaleffects/installroot/opt/qt5/lib64/qt5/qml/QtGraphicalEffects/private/DropShadowBase.qmlc
Error copying /home/rinigus/qt/qtgraphicaleffects/upstream/qml/QtGraphicalEffects/private/DropShadowBase.qmlc to /home/rinigus/qt/qtgraphicaleffects/installroot/opt/qt5/lib64/qt5/qml/QtGraphicalEffects/private/DropShadowBase.qmlc: Cannot open /home/rinigus/qt/qtgraphicaleffects/upstream/qml/QtGraphicalEffects/private/DropShadowBase.qmlc for input
make[3]: *** [Makefile:1429: install_qmlcacheinst] Error 3
make[3]: Leaving directory '/home/rinigus/qt/qtgraphicaleffects/upstream/src/effects/private'
make[2]: *** [Makefile:77: sub-private-install_subtargets] Error 2
make[2]: Leaving directory '/home/rinigus/qt/qtgraphicaleffects/upstream/src/effects'
make[1]: *** [Makefile:59: sub-effects-install_subtargets] Error 2
make[1]: Leaving directory '/home/rinigus/qt/qtgraphicaleffects/upstream/src'
make: *** [Makefile:60: sub-src-install_subtargets] Error 2
error: Bad exit status from /var/tmp/rpm-tmp.mOM0VG (%install)
RPM build errors:
Messages from sb2:
 (WARNING)      qmake[1156975/-142907584]       Path not found for FD 3, for __fxstatat64()
Examining the corresponding file:
ls -l /home/rinigus/qt/qtgraphicaleffects/upstream/qml/QtGraphicalEffects/private/DropShadowBase.qmlc
---------- 1 rinigus rinigus 7424 Mar 21 23:03 /home/rinigus/qt/qtgraphicaleffects/upstream/qml/QtGraphicalEffects/private/DropShadowBase.qmlc
None
The issue can occur earlier in the build as well. As a result we have used constructions like
%make_build  -k || chmod -R ugo+r . || true
%make_build
in some RPM SPECs while packaging Qt 5.15. Issue happens at OBS as well.
Thanks for the report, added to internal bugzilla
This bug has been major problem in packaging Qt6. Seems like calls to
/usr/lib64/qt6/libexec/qmltyperegistrar
would lead to that. As a result, we had to build large fraction of Qt6 packages using QEMU and docker build containers. Typical case demonstrating a bug:
  • during compilation, you have a call:
    [ 75s] [42/50] cd /home/abuild/rpmbuild/BUILD/kf6-kiconthemes-6.6.0+main.20241004220339.b70f889/upstream/aarch64-meego-linux-gnu/src/qml && /usr/lib64/qt6/libexec/qmltyperegistrar --generate-qmltypes=/home/abuild/rpmbuild/BUILD/kf6-kiconthemes-6.6.0+main.20241004220339.b70f889/upstream/aarch64-meego-linux-gnu/bin/org/kde/iconthemes/iconthemesplugin.qmltypes --import-name=org.kde.iconthemes --major-version=1 --minor-version=0 @/home/abuild/rpmbuild/BUILD/kf6-kiconthemes-6.6.0+main.20241004220339.b70f889/upstream/aarch64-meego-linux-gnu/src/qml/qmltypes/iconthemesplugin_foreign_types.txt -o /home/abuild/rpmbuild/BUILD/kf6-kiconthemes-6.6.0+main.20241004220339.b70f889/upstream/aarch64-meego-linux-gnu/src/qml/iconthemesplugin_qmltyperegistrations.cpp /home/abuild/rpmbuild/BUILD/kf6-kiconthemes-6.6.0+main.20241004220339.b70f889/upstream/aarch64-meego-linux-gnu/src/qml/meta_types/qt6iconthemesplugin_release_metatypes.json && /usr/bin/cmake -E make_directory /home/abuild/rpmbuild/BUILD/kf6-kiconthemes-6.6.0+main.20241004220339.b70f889/upstream/aarch64-meego-linux-gnu/src/qml/.qt/qmltypes && /usr/bin/cmake -E touch /home/abuild/rpmbuild/BUILD/kf6-kiconthemes-6.6.0+main.20241004220339.b70f889/upstream/aarch64-meego-linux-gnu/src/qml/.qt/qmltypes/iconthemesplugin.qmltypes
  • later, in install phase:
    [ 83s] CMake Error at aarch64-meego-linux-gnu/src/qml/cmake_install.cmake:94 (file):
    [ 83s] file INSTALL cannot find
    [ 83s] “/home/abuild/rpmbuild/BUILD/kf6-kiconthemes-6.6.0+main.20241004220339.b70f889/upstream/aarch64-meego-linux-gnu/bin/org/kde/iconthemes/iconthemesplugin.qmltypes”:
    [ 83s] Permission denied.
    [ 83s] Call Stack (most recent call first):
    [ 83s] aarch64-meego-linux-gnu/src/cmake_install.cmake:52 (include)
    [ 83s] aarch64-meego-linux-gnu/cmake_install.cmake:51 (include)
At OBS logs, you also get at the end
[   85s]  (WARNING)	qmltyperegistrar[3856/-143435968]	Path not found for FD 4, for __fxstatat64()
[   85s]  (WARNING)	qmltyperegistrar[3856/-143435968]	Path not found for FD 6, for __fxstatat64()
In general, these warnings with __fxstatat64 are rather frequent in the logs for all aarch64 packages of Qt6 - even if it manages to build them. Offenders are moc and others. Curiously, that’s not the case for regular SFOS packages (checked couple).
see SB2 Bug using std::filesystem
