Sometimes I need a bigger, clearer view when developing an app, so I use Emulator in the SDK, but not matter which project i try to run in emulator, I get this same error message and the build/install fails;
14:06:54: Starting: "C:\SailfishOS\bin\sfdk.exe" -c "device=Sailfish OS Emulator 4.4.0.58" deploy --
sdk
sfdk: [I] Options from environment: -c target=SailfishOS-4.4.0.58-i486
NOTICE: Using the 'SailfishOS-4.4.0.58-i486.default' snapshot of the build target
sending incremental file list
harbour-bmw-e46-0.1-1.i486.rpm
sent 218,165 bytes received 35 bytes 436,400.00 bytes/sec
total size is 218,001 speedup is 1.00
Installing harbour-bmw-e46-0.1-1.i486.rpm
Please confirm installation on device.
harbour-bmw-e46: [PK_TMP_DIR|dir:/var/tmp/TmpDir.JPDMkY] Repository already exists. (code: 4)
Installation failed
Deploy failed
14:07:05: The process "C:\SailfishOS\bin\sfdk.exe" exited with code 1.
Error while building/deploying project harbour-bmw-e46 (kit: SailfishOS-4.4.0.58-i486 (in Sailfish
SDK Build Engine))
When executing step "RPM Deploy"
14:07:05: Elapsed time: 00:44.
What do I need to do here?, where is PK_TMP_DIR…?, any clues please, I need to see details that my 52 year old eyes cannot see on my device (Sony Xperia 10ii).
Yes, every project, they all build on the device but no in emulator.
Okay, so I have just reset emulator and now the virtual machine does not start…“Connecting to the “SailfishOS-4.4-0.58” virtual machine”…it just sits there (this is not uncommon and is the start of less and less things working until I reinstall SDK…this is happening at least once a week. If i were to report ALL the problems I encounter with SDK, it would be the only thing I ever post.
It’s been a good 4 minutes and still I am waiting for the above connection…time to reinstall, {{{sigh}}}.
Right, I’ ve now actually got my app to run on emulator, for which I have selected to view in landscape, but it is virtually unusable, I’ll explain why in another post.
Perhaps a few times?, yes you are correct, it took a few starts and now its loaded in emulator…wow, what a mess the emulator is when in landscape…console is giving an error as well;
[W] unknown:11 - file:///usr/lib/qt5/qml/Sailfish/Silica/private/CoverWindow.qml:11: ReferenceError:
Config is not defined
I’ll make another post about these problems. I guess not many users are devving apps in landscape.
Windows 10 + hyper-v + VirtualBox + 32 bit linux as a guest is not a great combination. Unfortunately it’s all we’ve got. If you don’t need hyper-v for anything you can disable it and it will help a lot.
You are probably right about not many developing apps in landscape mode with the emulator. So your feedback will be appreciated, thanks already!
2 years later, thereabouts, back to the same problem, but I guess there is no help.
My last install of SDK seemed to break, first emulator stopped building, then building apps on my device failed.
I did a fresh install. I can build on my device, but cannot get one single build to go in the emulator?
I don’t understand why the SDK works generally and then at other times, it’s a no-go. Another reason to stop bothering to use SailfishOS when the SDK doesn’t want to work, what’s the point of any of it if apps cannot be made?
