SDK Sailfish OS Build Engine error
Hi,
When i try to build my app with the lasted SDK i get always:
RPM build errors:
error: Bad exit status from /var/tmp/rpm-tmp.7V89AB (%install)
17:20:03: The process “/home/rudi/.config/SailfishSDK/libsfdk/build-target-tools/Sailfish OS Build Engine/SailfishOS-3.3.0.16-armv7hl/rpm” exited with code 1.
Error while building/deploying project harbour-fileman (kit: SailfishOS-3.3.0.16-armv7hl (in Sailfish OS Build Engine))
The kit SailfishOS-3.3.0.16-armv7hl (in Sailfish OS Build Engine) has configuration issues which might be the root cause for this problem.
When executing step “RPM”
17:20:03: Elapsed time: 03:08.
Anyone has an idea how to fix this, i have reinstall Ubuntu complete and the SDK from start but i have been keep getting this problem…
Thanks!
When you get this errors the solution is the clean the builds.
Problem is now solved!
