I’m on SDK version 2.2.4, but I haven’t seen a nag to upgrade recently. When I click Help|Check for Updates, I see the green progress bar but I get no output.
So I tried the SDK Maintenance Tool Update Components function and after quickly downloading some repo stuff, it show the following error message:
Exception while loading the component script “/tmp/remoterepo-7ax1MW/org.merproject.mersdk/installscript.qs”: SyntaxError: Unexpected token `’ on line number: 393
At this point, I can’t do anything but OK the error message and quit the tool. If I look at the tmp file before quitting the Maintenance Tool cleans it up, I can see the line in question, but I don’t have the knowledge to attempt to debug the problem.
Is this fixable or work-aroundable? Is my installed version too old to upgrade? Should I just remove the existing SDK version and start over with a fresh install (will the Maintenance Tool successfully uninstall the old one?)
