Ubuntu 18 bionic
vboxmanage 5.2.42_Ubuntur137960
[SOLVED the vbox INSTALL problem, i think, see below]
Output (repeated this so often, this is output from the shell where Maintain Sailfish SDK is running):
[3512280] Warning: VBoxManage: error: Could not find a registered machine named ‘Sailfish OS Build Engine’\nVBoxManage:
[3512280] Warning: error: Details: code VBOX_E_OBJECT_NOT_FOUND (0x80bb0001), component VirtualBoxWrap, interface IVirtualBox, callee nsISupports\nVBoxManage: error: Context: “FindMachine(Bstr(VMNameOrUuid).raw(), machine.asOutParam())” at line 2871 of file VBoxManageInfo.cpp\n
[3512284] Warning: sfdk.vms: [W] Process “/usr/bin/VBoxManage” exited with unexpected exit code 1 . Arguments: (“showvminfo”, “Sailfish OS Build Engine”, “–machinereadable”)\n
[3512284] Warning: [D] SOFT ASSERT: “ok” in file …/…/…/…/sailfish-qtcreator/src/libs/sfdk/buildengine.cpp, line 468\n
[3512284] Warning: [D] SOFT ASSERT: “!reader.hasError()” in file …/…/…/…/sailfish-qtcreator/src/libs/sfdk/buildengine.cpp, line 653\n
[3512321] Warning: VBoxManage
[3512321] Warning: :
[3512321] Warning: error:
[3512321] Warning: Could not find a registered machine named ‘Sailfish OS Build Engine’
[3512321] Warning: \n
[3512321] Warning: VBoxManage: error:
[3512322] Warning: Details: code VBOX_E_OBJECT_NOT_FOUND (0x80bb0001), component VirtualBoxWrap, interface IVirtualBox, callee nsISupports\nVBoxManage: error: Context: “FindMachine(Bstr(VMNameOrUuid).raw(), machine.asOutParam())” at line 2871 of file VBoxManageInfo.cpp\n
[3512334] Warning: sfdk.vms: [W] Process “/usr/bin/VBoxManage” exited with unexpected exit code 1 . Arguments: (“showvminfo”, “Sailfish OS Build Engine”)\n
[3512336] Warning: sfdk.lib: [W] VmConnection: “Failed to start virtual machine \“Sailfish OS Build Engine\””\n
[3512367] Warning: VBoxManage: error: Could not find a registered machine named ‘Sailfish OS Build Engine’\nVBoxManage
[3512367] Warning: : error: Details: code VBOX_E_OBJECT_NOT_FOUND (0x80bb0001), component VirtualBoxWrap, interface IVirtualBox, callee nsISupports\nVBoxManage: error: Context: “FindMachine(Bstr(VMNameOrUuid).raw(), machine.asOutParam())” at line 2871 of file VBoxManageInfo.cpp\n
[3512379] Warning: sfdk.vms: [W] Process “/usr/bin/VBoxManage” exited with unexpected exit code 1 . Arguments: (“showvminfo”, “Sailfish OS Build Engine”)\n
[3512415] Warning: VBoxManage: error: Could not find a registered machine named ‘Sailfish OS Build Engine’\n
[3512416] Warning: VBoxManage: error: Details: code VBOX_E_OBJECT_NOT_FOUND (0x80bb0001), component VirtualBoxWrap, interface IVirtualBox, callee nsISupports\nVBoxManage: error: Context: “FindMachine(Bstr(pszVM).raw(), machine.asOutParam())” at line 595 of file VBoxManageMisc.cpp\n
[3512428] Warning: sfdk.vms: [W] Process “/usr/bin/VBoxManage” exited with unexpected exit code 1 . Arguments: (“startvm”, “Sailfish OS Build Engine”, “–type”, “headless”)\n
[3512428] Warning: No virtual machine with the name “Sailfish OS Build Engine” found. Check your installation.
If I do this manually (for instance vboxmanage createvm --name ‘Sailfish OS Build Engine’ --register --basefolder /home/mwa/SailfishOS/mersdk) I can add the images.
I even managed to get the emulator running.
This is so slow and time consuming since the installer download again and again.
virtualbox is fine (in that I have Plan9 and Freebsd images running without issues).
What can I do? I tried a complete re-install and it’s the same again and again.
I have a Volla phone. And and FP2.
