REPRODUCIBILITY: always
OS VERSION: 4.5.0.18
HARDWARE: SDK
UI LANGUAGE: NA
REGRESSION: Don’t know
Several packages from Qt 5.15 fail to compile on SDK with aarch64 with an error during compilation:
make[2]: Leaving directory '/home/rinigus/qt/qtdeclarative/upstream/src/qmltyperegistrar'
cd qml/ && ( test -e Makefile || /opt/qt5/bin/qmake -o Makefile /home/rinigus/qt/qtdeclarative/upstream/src/qml/qml.pro ) && make -f Makefile
Project MESSAGE: perl -w /opt/qt5/bin/syncqt.pl -module QtQml -version 5.15.8 -outdir /home/rinigus/qt/qtdeclarative/upstream -builddir /home/rinigus/qt/qtdeclarative/upstream /home/rinigus/qt/qtdeclarative/upstream
Use of uninitialized value $directory in concatenation (.) or string at /opt/qt5/bin/syncqt.pl line 691.
fileparse(): need a valid pathname at /opt/qt5/bin/syncqt.pl line 694.
Project ERROR: Failed to run: perl -w /opt/qt5/bin/syncqt.pl -module QtQml -version 5.15.8 -outdir /home/rinigus/qt/qtdeclarative/upstream -builddir /home/rinigus/qt/qtdeclarative/upstream /home/rinigus/qt/qtdeclarative/upstream
make[1]: *** [Makefile:102: sub-qml-make_first-ordered] Error 3
make[1]: Leaving directory '/home/rinigus/qt/qtdeclarative/upstream/src'
make: *** [Makefile:50: sub-src-make_first] Error 2
error: Bad exit status from /var/tmp/rpm-tmp.3xJvHQ (%build)
RPM build errors:
Messages from sb2:
(WARNING) qmake[1152823/-142194880] Path not found for FD 3, for __fxstatat64()
At the same time, x86 version would work. Compilation would also work at OBS, see example package at Show home:rinigus:qt515:packaging / qtdeclarative - SailfishOS Open Build Service
Get latest SFOS target and tooling. Add following repositories to compile:
- adaptation-common ... https://releases.jolla.com/releases/4.5.0.18/jolla-hw/adaptation-common/aarch64/
- apps ... https://releases.jolla.com/jolla-apps/4.5.0.18/aarch64/
- customer-jolla ... https://releases.jolla.com/features/4.5.0.18/customers/jolla/aarch64/
- hotfixes ... https://releases.jolla.com/releases/4.5.0.18/hotfixes/aarch64/
- jolla ... https://releases.jolla.com/releases/4.5.0.18/jolla/aarch64/
- sdk ... https://releases.jolla.com/releases/4.5.0.18/sdk/aarch64/
Enabled repositories (user):
- qt515 ... https://repo.sailfishos.org/obs/home:/rinigus:/qt515:/packaging/sailfish_latest_aarch64/
- Clone recursively GitHub - sailfishos-chum/qtdeclarative
- Checkout commit accee6958069df6c245b511d0d35275e79286d4d
- try to compile:
mb2 -t devel-aarch64 build .
Corresponding section in successful log at OBS with the same target:
[ 69s] cd qml/ && ( test -e Makefile || /opt/qt5/bin/qmake -o Makefile /home/abuild/rpmbuild/BUILD/opt-qt5-qtdeclarative-5.15.8+main.20230317095755.accee69/upstream/src/qml/qml.pro ) && make -f Makefile
[ 69s] Project MESSAGE: perl -w /opt/qt5/bin/syncqt.pl -module QtQml -version 5.15.8 -outdir /home/abuild/rpmbuild/BUILD/opt-qt5-qtdeclarative-5.15.8+main.20230317095755.accee69/upstream -builddir /home/abuild/rpmbuild/BUILD/opt-qt5-qtdeclarative-5.15.8+main.20230317095755.accee69/upstream /home/abuild/rpmbuild/BUILD/opt-qt5-qtdeclarative-5.15.8+main.20230317095755.accee69/upstream
[ 71s] <srcbase> = /home/abuild/rpmbuild/BUILD/opt-qt5-qtdeclarative-5.15.8+main.20230317095755.accee69/upstream
[ 71s] <bldbase> = /home/abuild/rpmbuild/BUILD/opt-qt5-qtdeclarative-5.15.8+main.20230317095755.accee69/upstream
[ 71s] <outbase> = /home/abuild/rpmbuild/BUILD/opt-qt5-qtdeclarative-5.15.8+main.20230317095755.accee69/upstream
[ 71s] QtQml: created fwd-include header(s) for <srcbase>/src/qml/ { inlinecomponentutils_p.h (1), qtqmlcompilerglobal.h (1), qtqmlcompilerglobal_p.h (1), qtqmlglobal.h (1), qtqmlglobal_p.h (1) }
Compilation failed as shown in Description above.
Described in “preconditions” above
Similar errors were observed with several other modules of Qt 5.15
