After clicking on “Stations Map” the map page appears on the screen, keeps loading, and in the log I see
[W] unknown:44 - file:///usr/share/harbour-bikeme/qml/pages/InteractiveMap.qml:44:9: QML Map: Error: Plugin does not support mapping.
Error message: Qt Location requires app_id and app_code parameters.
Please register at https://developer.here.com/ to get your personal application credentials.
So I assume the module is correctly loaded.
Try to factory reset the emulator using Options > Sailfish OS > Emulator > Factory Reset... under Qt Creator.
