REPRODUCIBILITY: 100% when a new gdb version is out
OS VERSION: 4.5.0.18 / SDK 3.11 on linux
HARDWARE: n/a
UI LANGUAGE: n/a
REGRESSION: no
With the sdk a copy of gdb is installed in ~/SailfishOS/bin/. In default config the QT Creator uses this copy of gdb. And gdb use all the libs installed in /lib64 or /usr/lib64. So if the gdb version mismatch with the lib* versions the debug stops with an error.
Install newest SDK 3.11 on a linux pc.
- Install newest SDK 3.11 on a linux pc.
- Update the os on the linux pc (run a ‘dup’)
- Start debugging in QT Creator
Find quickly all errors
GDB crashed.
n/a
/var/log/messages shows:
Unexpected GDB stderr: “/home/nn/SailfishOS/bin/gdb: /lib64/libncursesw.so.6: version NCURSESW6_5.6.20061217' not found (required by /home/nn/SailfishOS/bin/gdb)\n/home/nn/SailfishOS/bin/gdb: /lib64/libncursesw.so.6: version NCURSESW6_5.3.20021019’ not found (required by /home/nn/SailfishOS/bin/gdb)\n/home/nn/SailfishOS/bin/gdb: /lib64/libncursesw.so.6: version `NCURSESW6_5.1.20000708’ not found (required by /home/nn/SailfishOS/bin/gdb)\n”
2024-10-14T13:18:18.565346+02:00 localhost env[5658]: *** UNEXPECTED STATE TRANSITION: Debugger::Internal::GdbEngine(0x55fc48255ef0, name = “GdbEngine”) “State changed from EngineSetupRequested(1) to InferiorShutdownRequested(12)”
