I was building harbour-clipper, which has some binaries (both static binary and libs) and at some point it seemed there was a memory issue. I believe when trying to build the 4.x aarch64.
Since then, I can’t build anything. The SDK is deployed on home with 35GB of free space.
Messages look like:
+ /home/mwa/SailfishOS/bin/sfdk qmake /home/mwa/src/sailfish/harbour-greenmahjong/harbour-simplemahjong.pro -spec linux-g++
sfdk: [I] Options from environment: -c target=SailfishOS-4.1.0.24-aarch64
error: db4 error(11) from dbenv->open: Resource temporarily unavailable
error: cannot open Packages index using db4 - Resource temporarily unavailable (11)
error: cannot open Packages database in /var/lib/rpm
Target initialization failed:
Rpm Exception
mkdir: cannot create directory ‘/home/mersdk/.mb2/wrappers/build-harbour-simplemahjong-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release’: No space left on device
mkdir: cannot create directory ‘/home/mersdk/.mb2/user-wrappers/build-harbour-simplemahjong-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release’: No space left on device
/usr/bin/mb2: line 1430: /home/mersdk/.mb2/wrappers/build-harbour-simplemahjong-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release/qmake: No such file or directory
chmod: cannot access '/home/mersdk/.mb2/wrappers/build-harbour-simplemahjong-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release/qmake': No such file or directory
/usr/bin/mb2: line 1790: /home/mersdk/.mb2/wrappers/build-harbour-simplemahjong-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release/make: No such file or directory
On a whim, restarted the machine and now I got this far:
+ /home/mwa/SailfishOS/bin/sfdk qmake /home/mwa/src/sailfish/harbour-clipper/harbour-clipper.pro -spec linux-g++
Rpm Exception
mkdir: cannot create directory ‘/home/mersdk/.mb2/wrappers/build-harbour-clipper-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release’: No space left on device
mkdir: cannot create directory ‘/home/mersdk/.mb2/user-wrappers/build-harbour-clipper-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release’: No space left on device
/usr/bin/mb2: line 1430: /home/mersdk/.mb2/wrappers/build-harbour-clipper-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release/qmake: No such file or directory
chmod: cannot access '/home/mersdk/.mb2/wrappers/build-harbour-clipper-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release/qmake': No such file or directory
/usr/bin/mb2: line 1790: /home/mersdk/.mb2/wrappers/build-harbour-clipper-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release/make: No such file or directory
chmod: cannot access '/home/mersdk/.mb2/wrappers/build-harbour-clipper-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release/make': No such file or directory
Building target platforms: aarch64-meego-linux-gnu
Building for target aarch64-meego-linux-gnu
Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.irPU6c
+ umask 022
+ cd /home/mwa/src/sailfish/build-harbour-clipper-SailfishOS_4_1_0_24_aarch64_in_Sailfish_OS_Build_Engine-Release
+ LANG=C
+ export LANG
+ unset DISPLAY
+ CFLAGS='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -march=armv8-a'
+ export CFLAGS
+ CXXFLAGS='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -march=armv8-a'
+ export CXXFLAGS
+ FFLAGS='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -march=armv8-a -I/usr/lib64/gfortran/modules'
+ export FFLAGS
+ LD_AS_NEEDED=1
+ export LD_AS_NEEDED
+ export QT_SELECT=5
+ QT_SELECT=5
+ qmake -qt=5 -makefile 'QMAKE_CFLAGS_RELEASE=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -march=armv8-a' 'QMAKE_CFLAGS_DEBUG=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -march=armv8-a' 'QMAKE_CXXFLAGS_RELEASE=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -march=armv8-a' 'QMAKE_CXXFLAGS_DEBUG=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -march=armv8-a' QMAKE_STRIP=: PREFIX=/usr LIBDIR=/usr/lib64
Usage: /usr/lib64/qt5/bin/qmake [mode] [options] [files]
QMake has two modes, one mode for generating project files based on
some heuristics, and the other for generating makefiles. Normally you
shouldn't need to specify a mode, as makefile generation is the default
mode for qmake, but you may use this to test qmake on an existing project
Mode:
-project Put qmake into project file generation mode
In this mode qmake interprets files as files to
be built,
defaults to *; *; *; *.ts; *.xlf; *.qrc
Note: The created .pro file probably will
need to be edited. For example add the QT variable to
specify what modules are required.
-makefile Put qmake into makefile generation mode (default)
In this mode qmake interprets files as project files to
be processed, if skipped qmake will try to find a project
file in your current working directory
Warnings Options:
-Wnone Turn off all warnings; specific ones may be re-enabled by
later -W options
-Wall Turn on all warnings
-Wparser Turn on parser warnings
-Wlogic Turn on logic warnings (on by default)
-Wdeprecated Turn on deprecation warnings (on by default)
Options:
* You can place any variable assignment in options and it will be *
* processed as if it was in [files]. These assignments will be parsed *
* before [files]. *
-o file Write output to file
-d Increase debug level
-t templ Overrides TEMPLATE as templ
-tp prefix Overrides TEMPLATE so that prefix is prefixed into the value
-help This help
-v Version information
-after All variable assignments after this will be
parsed after [files]
-norecursive Don't do a recursive search
-recursive Do a recursive search
-set <prop> <value> Set persistent property
-unset <prop> Unset persistent property
-query <prop> Query persistent property. Show all if <prop> is empty.
-cache file Use file as cache [makefile mode only]
-spec spec Use spec as QMAKESPEC [makefile mode only]
-nocache Don't use a cache file [makefile mode only]
-nodepend Don't generate dependencies [makefile mode only]
-nomoc Don't generate moc targets [makefile mode only]
-nopwd Don't look for files in pwd [project mode only]
RPM build errors:
error: Bad exit status from /var/tmp/rpm-tmp.irPU6c (%build)
18:42:26: The process "/home/mwa/.config/SailfishSDK/libsfdk/build-target-tools/Sailfish OS Build Engine/SailfishOS-4.1.0.24-aarch64/qmake" exited with code 1.
Error while building/deploying project harbour-clipper (kit: SailfishOS-4.1.0.24-aarch64 (in Sailfish OS Build Engine))
The kit SailfishOS-4.1.0.24-aarch64 (in Sailfish OS Build Engine) has configuration issues which might be the root cause for this problem.
When executing step "qmake"
could be the actual error. The docker build doesn’t work for me out of the box, so I’m using the Virtualbox-based SDK → that’s a real VM with limited disk space (irrespective of how much free space is available on the host).
I observed this behaviour when trying to build components of osm-server, too.
Both RAM and disk space were not sufficient in the default configuration (of course this depends on how much other stuff you have compiled in the VM previously, as there might be some leftovers).
You can increase the storage space available to the SDK Build Engine VM either under Qt Creator Options > Sailfish OS > Build Engine or from command line with sfdk engine set.
Yes, help-building too, but it’s a bit shy on examples … it’s under the rubric: Build engine properties (go figure) … so here the bits.
vm.cpu-count <number>
The number of virtual CPUs inside the build engine virtual machine.
The maximum is limited by the number of CPUs available on the host.
vm.memory-size <megabytes>
The amount of memory (RAM) available to the build engine virtual
machine. The maximum is limited by the size of the physical memory
vm.storage-size <megabytes>
The amount of storage (disk) space available to the build engine
virtual machine. Storage size can only grow; shrinking is not
possible.
possible.
vm.swap-size <megabytes>
The size of swap. Setting to zero disables swap (default). Swap may
consume the free storage size inside the virtual machine. If the
requested size cannot be served, the highest possible size will be
set instead.
set instead.
