SDK 4.5.0.16 Emulator not recognising org.freedesktop.contextkit
REPRODUCIBILITY: 100%
OS VERSION: 4.5.0.16 EA
HARDWARE: Xperia 10 II
UI LANGUAGE: English
REGRESSION: Yes
Building my project was not a problem under the previous SDK release, the import statement for contextkit was underlined, but all aspects of the kit worked and gave desired readings; temp, voltage, etc
The latest EA 4.5.0.16 for SDK does not recognise “import org.freedesktop.contextkit 1.0” and the emulator displays a white window with the following errors:
[I] unknown:0 - QmlLive Bench connected
[W] unknown:7 - file:///usr/share/harbour-bmw-e46/qml/harbour-bmw-e46.qml:7:30: Type FirstPage
unavailable
initialPage: Component { FirstPage { } }
[W] unknown:11 - file:///usr/share/harbour-bmw-e46/qml/pages/FirstPage.qml:11:1: module
"org.freedesktop.contextkit" is not installed
[D] unknown:0 - 	activate document:  "qml/harbour-bmw-e46.qml"
I have run qmake and cleaned the project several times, even hashing out all things related to contextkit but still I am left with a white screen on emulator.
However, the same project displays and works correctly on my Xperia 10 II, all aspects of context kit are working and to add; the import statement for contextkit is no longer underlined in red. So I assume the problem is with SDK.
Have a project that uses “import org.freedesktop.contextkit 1.0”
Build your project!
Project should build and display correctly in emulator
Emulator shows a white background with errors given in console
None
Do you have qml(org.freedesktop.contextkit) in the Requires of your app?
Thanks @vige,
I did already have;
 Requires:   qml(org.freedesktop.contextkit)
in my SPEC file but I was missing the following from my YAML file;
    # Runtime dependencies which are not automatically detected
    Requires:
      - qml(org.freedesktop.contextkit)
with that line added to the YAML file, I can continue building between my device and emulator.
I came here just now to update my post to say I had worked out what was wrong and saw your reply.
