I downloaded SailfishSDK-3.4.9-linux64-offline.run, installed it and tried to compile my own creation with it. It has BuildRequires: pkgconfig(nemonotifications-qt5) so my solution to make sure it’s installed is as follows:
- Select i486 / aarch64 / armv7hl
- Touch the .spec file to trigger dependency check
- i486 and aarch64 install the necessary packages as expected
However, on armv7hl I get the following error:
Error building the cache:
Can't create cache at /home/.zypp-cache/solv/jolla - no writing permissions.
Some of the repositories have not been refreshed because of an error.
The only thing that I could check is that /srv/mer/targets/*/home/.zypp-cache exists and they have the same contents and permissions…
However, I managed to do this via root ssh:
chroot /srv/mer/targets/SailfishOS-4.0.1.48-armv7hl/
zypper ref
zypper install nemo-qml-plugin-notifications-qt5-devel
The package is installed, and I can successfully compile the package - the error message above stays the same. It takes time - sometimes it hangs over acquiring some sort lock - and is really annoying. How to resolve this?
