REPRODUCIBILITY: always
BUILD ID: 3.2.10
HARDWARE: VirtualBox emulator
UI LANGUAGE: Czech
REGRESSION: No
I recently unistall my SDK and install it again and configure Docker-based build engine. I do it twice, before second attempt, I was deleting all (I hope) SDK configuration: rm -rf ~/.config/QtProject ~/.config/Sailfish*, but the result is the same. I cannot deploy my project to emulator VM machine using sfdk command. It works fine with physical devices.
Running on Kubuntu 20.04 with docker 19.03.8, virtualbox 6.1.12
- I have these configured devices:
$ sfdk device list
#0 "Sailfish OS Emulator 3.3.0.16"
emulator autodetected nemo@127.0.0.1:2223
private-key: ~/SailfishOS/vmshare/ssh/private_keys/Sailfish_OS-Emulator-latest/nemo
#1 "Jolla"
hardware-device user-defined nemo@192.168.1.101:22
private-key: ~/.ssh/id_rsa_jolla
#2 "Intex"
hardware-device user-defined nemo@192.168.1.112:22
private-key: ~/.ssh/id_rsa_intex
- I am able to connect to Emulator with ssh and even with
sfdk device exec:
$ sfdk emulator start "Sailfish OS Emulator 3.3.0.16"
$ sfdk config "device=Sailfish OS Emulator 3.3.0.16"
$ sfdk device exec -- /bin/bash
[nemo@SailfishEmul ~]$ whoami
nemo
[nemo@SailfishEmul ~]$ sudo ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP qlen 1000
link/ether 08:00:27:7e:50:7f brd ff:ff:ff:ff:ff:ff
inet 10.0.2.15/24 brd 10.0.2.255 scope global eth0
3: eth1: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP qlen 1000
link/ether 08:00:5a:11:00:01 brd ff:ff:ff:ff:ff:ff
inet 10.220.220.1/24 brd 10.220.220.255 scope global eth1
- but when I build my project, I am unable to deploy it with sfdk:
$ cd ~/SailfishOS/projects/osmscout-sailfish
$ sfdk config "target=SailfishOS-3.3.0.16-armv7hl"
$ sfdk --quiet build
$ sfdk --debug deploy --sdk
sfdk: [D] About to run on build engine: "mb2" arguments: ("--device", "Sailfish OS Emulator 3.3.0.16", "--target", "SailfishOS-3.3.0.16-armv7hl", "deploy", "--sdk")
sfdk: [D] Mapping "/home/karry/SailfishOS/mersdk/targets/SailfishOS-3.3.0.16-armv7hl/" as "/"
sfdk: [D] Mapping "/home/karry/SailfishOS/mersdk/targets/SailfishOS-3.3.0.16-armv7hl" as "/"
sfdk: [D] Mapping "/home/karry" as "/home/mersdk/share"
sfdk: [D] Mapping "/home/karry" as "/home/src1"
sfdk: [D] Command after mapping engine paths: "mb2" arguments: ("--device", "Sailfish OS Emulator 3.3.0.16", "--target", "SailfishOS-3.3.0.16-armv7hl", "deploy", "--sdk") CWD: "/home/mersdk/share/SailfishOS/projects/osmscout-sailfish"
sfdk: [D] Task Sfdk::RemoteProcess(0x7ffe46c20890) transition: NotStarted --Started--> Running
sfdk: [D] Remote process ID: 39836 all data: "39836\n"
ssh: connect to host 10.220.220.1 port 22: Connection timed out
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(226) [sender=3.1.3]
sfdk: [D] Task Sfdk::RemoteProcess(0x7ffe46c20890) posting Exited
sfdk: [D] Task Sfdk::RemoteProcess(0x7ffe46c20890) transition: Running --Exited--> NotStarted
package is deployed on emulator
it fails
- my docker daemon configuration:
$ cat /etc/docker/daemon.json
"dns": [
"10.7.3.3",
"10.7.2.2",
"1.1.1.1",
"8.8.8.8"
"default-address-pools": [
"base" : "100.64.0.0/10",
"size" : 24
May be problem in non-default address space for docker? I tried to remove this configuration, restart docker daemon, but without efect. It is necessary to have VirtualBox and Docker in same network?
My docker networks:
$ docker network ls
NETWORK ID NAME DRIVER SCOPE
f0edef2eb79e bridge bridge local
d9198c269aa9 host host local
382503fd7e21 none null local
$ docker network inspect f0edef2eb79e d9198c269aa9 382503fd7e21
"Name": "bridge",
"Id": "f0edef2eb79ec7da9e5ecb01ce2bb8fc1bc8efbe78d5e5207737d1549eab1313",
"Created": "2020-08-29T15:09:02.982828619+02:00",
"Scope": "local",
"Driver": "bridge",
"EnableIPv6": false,
"IPAM": {
"Driver": "default",
"Options": null,
"Config": [
"Subnet": "100.64.0.0/24",
"Gateway": "100.64.0.1"
"Internal": false,
"Attachable": false,
"Ingress": false,
"ConfigFrom": {
"Network": ""
"ConfigOnly": false,
"Containers": {
"bcb601c834d32c84e7925e8706224e68e5e40c88758be1b6d02f6ff3c0503ba9": {
"Name": "sailfish-os-build-engine",
"EndpointID": "2d5a786a90aa1fa4f3bbd28ac7f1f75baf8644311636227eec18be263f043143",
"MacAddress": "02:42:64:40:00:02",
"IPv4Address": "100.64.0.2/24",
"IPv6Address": ""
"Options": {
"com.docker.network.bridge.default_bridge": "true",
"com.docker.network.bridge.enable_icc": "true",
"com.docker.network.bridge.enable_ip_masquerade": "true",
"com.docker.network.bridge.host_binding_ipv4": "0.0.0.0",
"com.docker.network.bridge.name": "docker0",
"com.docker.network.driver.mtu": "1500"
"Labels": {}
"Name": "host",
"Id": "d9198c269aa99dde21bcbce25318f9dba8aa8febebeca1a91033954724f66ae0",
"Created": "2019-12-13T14:54:48.742810928+01:00",
"Scope": "local",
"Driver": "host",
"IPAM": {
"Options": null,
"Config": []
"Internal": false,
"Ingress": false,
"ConfigFrom": {
"Network": ""
"Containers": {},
"Options": {},
"Labels": {}
"Name": "none",
"Id": "382503fd7e21ef6b8696ac3d81bda22707eae8724e8c13294c6deef13bd12132",
"Created": "2019-12-13T14:54:48.699517625+01:00",
"Scope": "local",
"Driver": "null",
"IPAM": {
"Options": null,
"Config": []
"Internal": false,
"Ingress": false,
"ConfigFrom": {
"Network": ""
"Containers": {},
"Options": {},
"Labels": {}
- network configuration on host:
$ ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
2: enp0s31f6: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 10:65:30:24:e6:89 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 34:41:5d:6b:16:1f brd ff:ff:ff:ff:ff:ff
inet 192.168.1.113/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
valid_lft 316577sec preferred_lft 316577sec
inet6 fe80::7cff:ba67:d657:c983/64 scope link noprefixroute
4: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 10:65:30:97:6c:04 brd ff:ff:ff:ff:ff:ff
5: vpn0: <POINTOPOINT,MULTICAST,NOARP> mtu 1406 qdisc fq_codel state DOWN group default qlen 500
link/none
6: vboxnet0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 0a:00:27:00:00:00 brd ff:ff:ff:ff:ff:ff
7: vboxnet1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 0a:00:27:00:00:01 brd ff:ff:ff:ff:ff:ff
9: docker0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
link/ether 02:42:57:9d:df:15 brd ff:ff:ff:ff:ff:ff
inet 100.64.0.1/24 brd 100.64.0.255 scope global docker0
inet6 fe80::42:57ff:fe9d:df15/64 scope link
35: vetha13cf69@if34: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master docker0 state UP group default
link/ether 5e:e2:50:d7:a6:9f brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::5ce2:50ff:fed7:a69f/64 scope link
