REPRODUCIBILITY (% or how often): 1/1 (just happened once, no idea)
BUILD ID:
HARDWARE (Jolla1, Tablet, XA2,…): Win10 upgrading SDK from 3.1 to 3.2
UI LANGUAGE:
Had Xperia X mode turned on in emulator in 3.1, after upgrade to 3.2 the result was a still huge window with just jollaC size (1/4th?) emulated in bottom left corner, after changing emulator mode to intex/jollac everything back to normal so not a huge issue
Upgrade from 3.1 to 3.2 while having Xperia mode in emulator
- Run 3.1 SDK
- Set Xperia as emulator target
- Upgrade to 3.2 SDK
Normal emulator window (who cares if it forgets last target I guess)
Bit weird, whole rendered window is in bottom left corner, touch still worked
(Please ALWAYS attach relevant data such as logs, screenshots, etc…) Ok
