Sometimes I got the following failure when building RPM with the latest SDK:
+ /usr/lib/rpm/find-debuginfo.sh -j4 --strict-build-id --build-id-seed 1.2-1 --unique-debug-suffix -1.2-1.arm --unique-debug-src-base vcardserializer-1.2-1.arm -S debugsourcefiles.list /home/mm/Projektek/jolla/harbour-sms-share-plugin/vcardserializer/
extracting debug info from /home/deploy/installroot/usr/lib/qt5/qml/hu/mm/vCardSerializer/libvCardSerializer.so
error: Bad exit status from /var/tmp/rpm-tmp.kVbFyA (%install)
RPM build errors:
Are there any hints what should I do in these cases? Sometimes restarting the build VM and the Creator and doing a rebuild solves the problem.
Agreed, although the errors I get are not the same as yours. It almost seems like SDK needs time to warm up. After 2 or 3 attempts it finally builds. I kind of expect troubles, as the current release is early access.
But I find myself more and more often analyzing strange one-time occurences or weird behaviour than years ago.
And yes those hiccups should have been deterministic but …
