I have a 128GB sdcard. If I format it on the phone I can’t access it from my pc (manjaro)…and vice versa. Some basic permission problem…can anyone help? TIA
https://together.jolla.com/question/195850/guide-creating-partitions-on-sd-card-optionally-encrypted/
might be helpful.
Thanks mSorvisto for the link…after some experimentation I copied my music files to the card on my pc and then on the phone used olf’s finish up commands:
devel-su
cd /run/media/nemo/
chown -v nemo:nemo */.
and that worked ok. But as far as I can tell if I try to take the card out and resync or copy more stuff on my pc it is no longer accessible.
I used ext4 on a samsung evo-pro 128gb.
