SD card stuck in Jolla C2 / how to open case?
Hello, I have a strange problem:
I recently got my Jolla C2, and installed my SD-card and SIM-card. SIM was detectetd, SD was not. So I re-opened the slot for the cards to check if they were installed correctly, pulled out the little tray, and only the SIM was on it. The SD card was stuck in the slot in the phone.
My efforts to remove it seem to only have driven it deeper into the phone.
So I think the only way to get the SD-card out would be to open the phone, but I haven’t found a manual how to do it. Can it be opened, and if yes, how?
Thanks,
WurzelDerMaacht
I found a Youtube video linked here in the forum, and it looks like opening the phone is out of the question.
So I’ll just accept that somewhere in the phone the old SD card exists (there was nothing important on it anyway, just music), and buy a new SD card to use.
Don’t worry too much; just cut a thin strip like the one in the photo, but make sure it’s this thin, and be careful not to touch the wires when placing it. That’s all there is to it; there’s nothing to worry about.
Your stuck SD-Card be like: Part of the Crew (Memory), Part of the Ship (C2)
Real Sailor Spirit :grin:
