Sailshark - Qt/QML frontend for Wireshark
a native Wireshark /Tshark) frontend for Sailfish OS.
Live packet capture · Protocol tree · Hex dump · Follow TCP Stream · Save .pcapng · Interface picker · BPF filters
Built on Wireshark 3.6.24 + Qt 5.6/Silica QML.
On my repository: Show home:nielnielsen / Sailshark - SailfishOS Open Build Service
Fantastic! I hope I’ll have my Jolla 2 before SharkFest. :heart_eyes:
Is there somewhere an hiwto install available? Or is it available in openrepos / storeman too?
@Demonia it is not in openrepos, so you have two choices.
  1. add my repository (devel-su zypper ar … … then pkcon install sailshark,
or
  1. download the RPM, and install it (pkcon install-local sailfsark.rpm you downloaded)
The will then be an icon to launch
Sorry, that is not working. I assume, i need to put the link to the repo after ar? What is the link?
depends on your device. If you are on aarch64, it is: devel-su zypper ar Index of /obs/home:/nielnielsen/sailfishos_latest_latest_aarch64 nieldk
or, download the RPM and install with pkcon install local
https://repo.sailfishos.org/obs/home:/nielnielsen/sailfishos_latest_latest_aarch64/aarch64/sailshark-1.1-1.20.1.bso.aarch64.rpm
Committed to chum:testing
together with chameleon ultra app
Shoot! They are now in chum:testing :tada::tada::tada:
Back from SharkFest Europe !
I showed the capture process to a few Core Developers, including Gerald Combs himself who said “That’s neat !” (and I must say, I do agree).
Sure, the analysis is much easier on a big screen but the ability to capture directly on the phone is clearly useful and we can still do a preliminary analysis on-device.
Thanks for that port/frontend !
How cool is that :smiling_face_with_three_hearts: ………
