SailReef - native QML saltwater reef parameters tracker
Do you have coral reef?
Now you can track your saltwater aquarium for measured parameters on your Jolla Phone!
This version allows you to:
  • create, rename, and delete aquariums
  • enable or disable up to 61 water parameters for tracking
  • log your last water change date
  • search for parameter name or chemical symbol
  • filter values by their relation to the ideal range
  • pin favorites on the top of the list
  • history of measured values, including link to Fauna Marine Knowledge base
  • edit or delete measured values in history view, including water change volume
  • support for My Backup
  • import Fauna Marin ICP lab results from CSV file (must be exported in English)
Actual min/max values for each parameter are set for my needs, lets see if there are some other sailors with coral reefs, let me know in comments! :slight_smile:
In the next versions there could be:
  • custom water parameters
  • custom minimum and maximum values for each parameter
If you have Hanna HI736 ULR Phosphorus checker, you can type directly Phosphorus values and app will convert to Phosphate automatically :wink:
You can use this app for fresh water aquarium too, so you will enable only few parameters like nitrate, phosphate, ph, kh …
Source: koza/harbour-sailreef - Codeberg.org
No AI just pure goat code.
Screenshots:
Download:
