Now that sharing plugins are run out-of-process from where it was invoked from, they no longer inherit permissions from that app, which is good. However, currently they seem to have full user permissions, which isn’t so good.
Since SailJail permissions are .desktop-file based and sharing plugins doesn’t have any, how will that work?
Maybe @vige can contribute to this, because it would be really helpful to learn something specific about how to let an app perform “sharing” (on the sending and receiving end) in conjunction with SailJail, now that SailfishOS 4.4.0 EA is released.
Generally the sharing system will show a dialog to choose an application to use for sharing. The selected application will run with its own privileges. On some cases the sharing will be done inside the dialog, but that is restricted for the system side, e.g. bluetooth which wouldn’t have any application either.
If app can be used for sharing, it should declare related properties in the .desktop file.
I was under the impression that’s all related. But then, I was just now also thinking about Contacts (Fernschreiber not being able to access…) and Sailjail.
With sharing plugins being run out-of-process, i mean that the dialog that is provided by the plugin is run in a separate process from the app that invoked it. Example sharing plugin: https://github.com/attah/harbour-seaprint-share-plugin.
So i was wondering what limitations SailJail will put on what those can do, when they themselves have no place to declare permissions. This is mostly in the light of that i invoke SeaPrint from my plugin.
The answers i interpret as that sharing plugins will only ever have base permissions. And the need for doing fancy things in plugins (and making plugins) should be greatly reduced by the upcoming open-with functionality (already available for Android apps). This is what you linked to, but it may get a bit repackaged since it isn’t released/allowed yet.
My sharing plugin was only really ever a workaround, so i’m happy sharing to SeaPrint will become much cleaner and easier. If just in a version or two…
Ah, I hadn’t thought of the dialog. Thanks for clearing that up. Now how do I test your plugin? Does it need to be built/installed separately from seaprint? I was testing with v1.0.4.
Sadly, on 4.4 you don’t. The sharing infrastructure has changed again, and even if i was to adapt to it, the plugin would be too jailed to do what it currently does. But otherwise, you just install it alongside SeaPrint (it is packaged in OpenRepos).
