As I read out here, there are always bugs that are sometimes more or less well solved.
This should not happen with a quite mature operating system. Especially not such different bugs and little things that cannot be removed for years. The lte forum is full of such messages.
What should I think about it?
Should I really switch to Android or iOS?
After all, my Aqua Fish said goodbye last Saturday and does not work anymore. [At the moment I want to do the factory reset, but I canāt get any further]. (Factory reset - recovery not working)(Maybe someone can help?)
With the original camera app this may be, but if you download the Advanced Camera app from Jolla store, then the camera gets itās full potential. Maximal pixel res. that I can choose on my Xperia 10 is 4208 x 3120 pixel and quality (colours, sensitivity, sharpness,ā¦) I consider as very good.
I had the Xperia X and it worked in Austria, Belgium, Denmark, Germany, Poland, The Netherlands, France and UK. Early SF versions sometimes needed a network restart after crossing the border.
I use an XA2 with version 4.1.0.24.
Since I donāt need Android apps, I canāt say anything about it.
The thought behind the change to another OS was just to go away from Android /IOS.
The battery level is about 45% in the evening.
Read the release notes carefully. Otherwise, GPS can also sometimes not provide results.
GPS fix takes me about 15 minutes. With luck, sometimes done in 5 minutes.
Mobile Internet or WLAN are very stable.
The standard camera takes a good picture at 17 MP resolution, but I do not have high demands on the camera.
I have installed āStoremanā as an alternative store.
Possibly read before what it has to do with the resize of the root partition.
I forgot and do not know if I can do that now without losing data.
