Sailfish WebView crashed sometimes when assigning URL
REPRODUCIBILITY: ~10% (sometimes)
OS VERSION: 4.5.0.18
HARDWARE: X, XA2
UI LANGUAGE: german
REGRESSION: no
Sailfish WebView seams stable when running in a simple app. But with some signal handlers and some settings in Component.onCompleted the Sailfish WebView API or the WebEngine crashed sometimes after
WebView.url = myURL
Signal handlers used:
WebView.onLoadedChanged, WebView.onLinkClicked, WebView.onLoadRedirect, WebView.onMovingChanged
Settings used:
WebView.pixelRatio, WebView.httpUserAgent, WebEngineSettings.javascriptEnabled, WebEngineSettings.autoLoadImages, WebEngineSettings.cookieBehavior
The settings will be applied after WebView.initalizied === true.
In my app (Ielig:Web) some history data where deleted in the app cache before starting. And the WebViewPage is typicall the third page in PageStack and sometimes a page can attached.
Create a more complex app than in the examples.
Less crashes
The app crashed but the cover page remain on the app grid.
No Android, nothing from OpenRepos or Chum
Maybe the crash frequency is little less on the XA2 (vs. X)
The new version of my app (Ielig:Web) is nearly ready for the Store. But in SF 4.5 the old QT WebKit is no more available for new releases apps. So the app has to work with the Sailffish WebView API. The SF WebView is a great browser. When the bug described here and this bug are fixed the new version will be released in Store.
Send PM for more details.
For your tests you can find the new beta Sailfish WebView API version of the app Ielig:Web here:
Ielig:Web RPM
17 posts were merged into an existing topic: Android Apps Using System Webview Crash
OK, I got the full stack trace. Should be enough for a formal bug report.
