I’m trying to set up the Sailfish OS SDK in a version of Ubuntu (Pop! OS -> Ubuntu 20.10 “Groovy”) on a mini PC. The SDK .run is downloaded and I tried to run it. I received a pop up message:
"Cannot find missing dependency “org.merproject.mersdkdocker” for “org.merproject.mersdk”.
I found this link:
on: https://docs.docker.com/engine/install/ubuntu/
I am not sure if it will help, but which one of these files do you think I need if this is what I do need to solve the dependency issue? I’ve done a little programming and would like to try it on Sailfish OS as time allows. I’m still new to Linux.
Thanks.
