Sailfish OS and phones
on which all phones is it possible to install Sailfish OS? if i buy for example motorola moto g8 power - is it possible to replace the android Sailfish OS? and is it difficult?
Hi,
At the moment Sailfish X is officially available for these devices:
Sony Xperia 10 Single SIM (I3113 & I3123)
Sony Xperia 10 Dual SIM (I4113 & I4193)
Sony Xperia 10 Plus Single SIM (I3213 & I3223)
Sony Xperia 10 Plus Dual SIM (I4213 & I4293)
Sony Xperia XA2 Single SIM (H3113 & H3123 & H3133)
Sony Xperia XA2 Dual SIM (H4113 & H4133)
Sony Xperia XA2 Plus Single-SIM (H3413)
Sony Xperia XA2 Plus Dual-SIM (H4413 & H4493)
Sony Xperia XA2 Ultra Single-SIM (H3213 & H3223)
Sony Xperia XA2 Ultra Dual-SIM (H4213 & H4233)
Sony Xperia X Single SIM (F5121)
Sony Xperia X Dual SIM (F5122)
Gemini PDA variants x25 and x27.
If you’re willing to try out a community port (an unsupported port by the community), there’s a list of supported devices and a compatibility matrix over here: https://wiki.merproject.org/wiki/Adaptations/libhybris.
If you’re going to buy a new phone I would recommend using an officially supported phone as listed in the reply above.
Do you think, that Nokia Lumia 520 can available in future for SailFish OS ?
This topic is extensively documented in [Wiki] Available devices, plus rumored and legacy devices, running Sailfish OS at TJC.
Thanks olf I have read this page
And the Xperia 5? Makes sense testing the platform in individual basis on our side?
Kind regards
I do not see any recent device in the Xperia X series that would fit in my pocket available in the stores. The last one Xperia 10 is worse than the Xperia XA2 and now XA2 can not be found even on the second hand market.
What are the plans of Jolla for the future. Which phones are to be expected to be officially supported on the European market?
