Wait until i update packages, then the process is
devel-su
ssu re 4.4.0.58
ssu ur
zypper ref
zypper dup
Thank you @piggz , I will do so. But how do I know that the update is ready and that it’s time to run the commands? Will you post here? or shall I have a look at another site?
Ill post it here… devel: channel is updated already, and seems to be ok, ill say when its promoted to testing: (for users)
Video recording bug remains though
4.4.0.58 is now available for Volla and Volla-X
Make sure you are already up to date:
zypper ref
zypper dup
Then update:
devel-su
ssu re 4.4.0.58
ssu ur
zypper ref
zypper dup
Works like a charm! Thanks very much!
edit: to make more precise what worked like a charm:
before the first zypper ref+dup: devel-su
between the first zypper ref+dup and the second block of commands: a reboot
yottagram share plugin caused a conflict, had to uninstall it.
update:
- phone works
- waydroid works
might be related to 4.4. and not the port:
- i have lost the avatars in phone / contacts app
- patchmanager did stop to work for me
What can I do to reduce keyboard height? It covers too much of screen content.
For experiment, I installed the patch ‘smaller keyboard’ by @ichthyosaurus from Patch Manager. This worked, but since this try, the font size in Internet Browser has changed, especially on the SFOS forum homepage (this homepage), despite it’s deinstalled meanwhile. (keyboard large again, but larger font on this forum page persists).
The ‘Smaller Keyboard’ patch is only for version - 3.4.0.24, how can I do this by CLI, that ‘Smaller Keyboard’ did?
And the top 1 cm of the keyboard is empty because Volla has no predictive text input. Can I also remove this unused area and free it for screen content?
Here is the source of the “smaller keyboard” patch: sailfish-public-patch-sources/sfos-patch-keyboard-smaller-keyboard at master · ichthyosaurus/sailfish-public-patch-sources · GitHub
I don’t have SFOS 4.x so I can’t help you there
I made a small error in the update, you may need to manually download and install this package
https://build.sailfishos.org/package/binaries/nemo:testing:hw:volla:yggdrasil:4.4.0.58/community-adaptation-testing?repository=sailfish_4.4.0.58_aarch64
and this package
If prompted about the second being uninstallable because another package required a different version, just choose option 3 to ignore it
then ref/dup again and hopefully all is good!
first package installed directly via ui. no problem
second one failed.
tried from cmd line, permission denied, is not a devel-su problem but my lacking knowledge
how do i install it from cmdline, which program to use ?
rppm maybe but with what options ?
did that:
rpm -i -p --force droid-config-yggdrasil-0.0.2-1.1.2.jolla.aarch64.rp
@piggz : How can I install the updates, using the two links?
actually, its maybe easier just to edit a file on the device
the file is
/usr/share/ssu/features.d/adaptation-commnity.ini
there is a URL in there for where the port packages are, it should be
https://repo.sailfishos.org/obs/nemo:/testing:/hw:/volla:/yggdrasil:/%(release)/sailfish_%(release)_%(arch)
After editing type
ssu ur
zypper ref
zypper dup
and all should (hopefully) be fine
I did click onvlink one, then there is a download button that leads.you to a list of file. There i looked by name for the two, download to laptip, copy over, ssh to devives and install them using.rpm, see above in my answer
Sadly, I wasn’t able to determine exactly when that started happening. I’m still on 3.4 as daily since I depend on Whisperfish. It looks as if the videos I made in the last months where on 3.4. But I transfer stuff often so it’s hard to tell.
Whisperfish is more or less usable now so I’ll switch soon. As soon as video recording is fixed
who needs video
i would need network sharing. does that work for anybody ?
Tried to c+p this … mind the typo… community
Then I got this:
[root@VollaPhone defaultuser]# zypper ref
Unerwartete Ausnahme.
Unzulässige fragment-Komponente: ‘#’
Senden Sie einen Fehlerbericht zu diesem Problem.
Anweisungen finden Sie unter http://de.opensuse.org/Zypper/Fehlersuche.
strange…
show the file via : cat /usr/share/ssu/features.d/adaptation-commnity.ini
as defaultuser: no such file or directory
as root: the same
edit: This is the content of the file:
[adaptation-community]
repos = adaptation-community
pattern = Feature community adaptation
description = Enable ssu for community ports
[repositories]
adaptation-community = https://repo.sailfishos.org/obs/nemo:/testing:/hw:/volla:/yggdrasil:/%(release)/sailfish_%(release)_%(arch)
“#” adaptation-community = https://repo.sailfishos.org/obs/nemo:/testing:/hw:/volla:/yggdrasil/sailfishos_%(release)/
edit: how can I write an “#” here at the beginning of a line? Without “” it makes
this!
You were instructed to edit, not comment out. The German error message complains about an illegal character “#”.
Make a backup of the file if you want but you need to remove the “#” and everything after it.
