Regarding file handling I can share my experience with Podcini hosted via F-Droid running on Sailfish OS AAS as example how not to do it.
-Podcini set to download to SD Card. All goes well: folders, naming, comments.. Building a little cosy house.
-Podcini complains external storage not accessible or mounted and automatically reverts to downloading on the device built in storage (Android partition in this case)
-Reboots & restarts of services, whole OS, or updates to Podcini don’t solve the issue.
-Re-selecting the SD Card storage under Podcini settings triggers a data migration process that whipes all previously downloaded data on the SD Card.
No warning!
Issue 100% reproducable. Weither or not this “losing track of SD card” is a Sailfish OS limited issue with Podcini and on native Android it runs fine, I can’t tell since I have no Android to test.
What I would have prefered:
Whenever locations change the user needs to be promted for action.
Automatic switch over from SD to Internal or visa versa should be conciously selected set in the settings
User should be warned about potential data overlap and folders should be merged or overwritten, database reset only when prompted the user for
Without any of that having been confirmed (automatic) downloads seize and functionally falls back to streaming untill memory issue resolved.
Without user interaction about the above their will be no autonomous switch over and the refresh system will check for SD present and just continue as before whenever the previously used SD card gets mounted.
When new SD is detected promt if user wants to download all previously downloaded episodes a new (reconstruct the archive based on DB held download statistics) or reset the download counter and start a brand new download folders structure (Podcini style)
SD Card storage support seems the only way to make an application like this complete.
Personally I find it quite easy to fill several hundreds of GB’s worth of historically or research relevant podcasts. The idea is not to take them out of one cloud (big podcast) to put them on another (i)cloud but to conserve for “offline on the go” and share locally to play back even on pre 2YK computers.
Thanks for taking the feature set of Sailcast next level, it was frankly quite unexpected after so many years of nothing moving.
