I am trying to backup my mobile using USB network and ssh, but I can’t find rsync anywhere. It’s not pre-installed, nor can I find it in Chum or Jolla Store… Any hints? I think open-repos is not recommended anymore… are there any other package sources I can use?
Well, it is just one of the frontends for rpm package management, so the application is very much googlable. Others prefer zypper.
Yes, a fair few basic utilities are part of the official repos. And honestly the best way to find out which is to make an educated guess and the use pkcon search, or at least that’s what i do.
I test r̶s̶y̶n̶c̶ rclone on my workplace pc with linux mint. It is faster in terms of speed against the inbuild webdav-mount. r̶s̶y̶n̶c̶ Rclone comes with a handy “installer” for creating new connections. You create once your config for a connection and then mount the resource with a oneliner-command. Much easier like the fstab or dav2fs attemp.
On my SailfishOS Daily Driver Sony XZ2 Compact i using dav2fs but will test r̶s̶y̶n̶c̶ rclone against it and will of course write a test/howto about it.
Yeah well which is usually exactly NOT downloading software from some random website but rather use the distro repos - but in this case we must because rclone is hard to build
