RPM harbour packages include bin path
The /usr/bin path is part of the filesystem package
# rpm -qf /usr/bin
filesystem-3.1+git5-1.7.1.jolla.noarch
but some applications do package it into there rpms:
# rpm -qf /usr/bin
harbour-screen-message-0.3.1-1.armv7hl
harbour-scribble-0.4-2.armv7hl
harbour-simplecrop-1.1.3-1.armv7hl
harbour-fishtheke-0.8-1.armv7hl
harbour-barcode-1.0.44-1.armv7hl
LANG=C rpm -V harbour-tasklist harbour-fahrplan2
.........    /usr/bin (replaced)
Maybe a check to prevent this should be included into the harbour validation process?
Easy mistake to make.
That does show up as an error as an Error in standard rpmlint run though, even if harbour doesn’t care.
harbour-simplecrop.armv7hl: E: standard-dir-owned-by-package /usr/bin
And yeah, this is a disease:
 $ rpm -qf /usr/bin | wc -l
156
The fix, by the way, is in the .spec file:
## do not do this:
%files
%{_bindir}
## do this:
%files
%{_bindir}/*
Thanks, I’m going to check my code today :sweat_smile:
And corrected as well :slight_smile:
I just checked this; when you create a new project, the .yaml file contains the following:
Files:
  - '%{_bindir}'
  - '%{_datadir}/%{name}'
  - '%{_datadir}/applications/%{name}.desktop'
  - '%{_datadir}/icons/hicolor/*/apps/%{name}.png'
I think %{_bindir}/* or even %{_bindir}/%{name} would do better. The former works with my Battery Buddy, as I ship two binaries, but most apps would do with the latter…
So, this is a bug in the skeleton project itself, too, and I guess Jolla packages are also using it…
Good catch, @vige maybe that would be some low-hanging fruit to fix in SDK 3.7.
Thank you, this is likely going to be fixed in SDK 3.8.
