Hello, I’m having a little problem with repos I manually add via the terminal.
Adding a repository like this works just fine: zypper ar -f https://sailfish.openrepos.net/<username>/personal-main.repo. But after I open the Jolla Store client it instantly disappears from my repo list. The same happens when Storeman refreshes its repositories.
The obvious solution here would be to not use the Jolla Store again. I’ve thought about removing the desktop entry of it, but I’m not sure if applications installed through the Jolla Store previously are updated as well with a zypper update (this of course includes core system applications like android app support). Does anyone know this, or have another solution for this problem?
Thanks!
