Remote management suddenly activated
A pop-up just showed up on my Xperia 10 claiming that Remote Management has been activated on my phone and that I had to contact system administrator if i need to know more.
This is a personal phone and I’m also doing some dev with it.
I’m not part of any organisation.
What’s going on?
How to be sure about the status related to remote management?
Thanks
Can you make a screenshot, please.
It’s a one time message. I didn’t capture it. You know the type of message that appears when you install a new app. If I see it again I will.
I just want to be sure that remote management is not enabled.
Was this after installing of a specific app?
edit: if yes, Android or SF app? Can you see this pop up in the old notifications?
Yes. An app I’m developping. Sorry I just understood why I got it. I used an API to get a unique ID related to the device. This is likely using this API that pops up this display. I close the issue.
