You don’t need to help me. I just don’t want to file a bug report if someone says that this problem is known. If it’s not known then I will file a report. No problem. Cheers.
If it’s a known problem, then why posting it in the first place? It does not make sense….
Please do not share information without providing the full picture:
As the FAQ says, you could at least tell which phone model, which firmware you’re on and which version of WhatsUp you’re currently using.
Without these, your shared information does not have any meaning at all.
In my tests, lipstick just stays at 1% and below 1% when the application is closed.
Model: Sony Xperia 10 III
WhatsUp version: 1.2.0
SFOS FW: 5.1.0.11
Sorry, my bad. Where do you want the report to be filed? Is there a github or gitlab project or right here?
you can do it here (just make sure it does not contain any sensitive information)
but regarding the lipstick, you might need to dive into the journal and see what is going on.
Could you at least tell me which device, which fw version and which WhatsUp version you’re on?
[BUG]
OS VERSION: 5.2.0.18
HARDWARE: JP2026
- With freshly started homescreen lipstick shows normal CPU usage
- Starting WhatsUp leads to too high CPU usage of lipstick even when GUI of WhatsUp is closed by swiping
- CPU usage of lipstick stays high even when WU gets closed completely by WU settings
- Restarting homescreen using helper programs brings lipsticks CPU usage back to normal
Screenshots see my post above.
Info about journal content concerning lipstick follows (will edit this post)
Is there a way to keep AAS.on but kill whatsapp? Despite me disabling start backgorund services and restarting AAS whatsapp still starts. So I am getting both whatsup and whatsapp notifications. This is on xperia 10 II.
You can disable WhatsApp notifications, in addition to not allowing it to start at boot, not allowing notifications to start the app through microG, and other relevant options I’ve forgotten. But it would still start from time to time…
Another thing, that helps even more, is to limit the number of background apps in Android’s system development settings. This one’s most effective for me. I use a value of 2 when only intending to use one Android app, and one of 3 when i need to switch between two Android apps. That’s because microG counts too.
i just installed it but i cant seem to join ongoing group calls. It doesnt show it taking place, though i can see it in the AAS version…
still, it feels great overall!
WhatsUp 1.3.0
New features
- Pin communities and groups within communities.
- Optionally show pinned community groups directly in the Groups tab.
- Join an ongoing group call, including switching from another linked device to WhatsUp.
- Saved pictures, videos and statuses now use the sender’s name or number and the original date and time.
Fixes
- Videos saved to the gallery now go into Videos instead of Pictures.
- Fixed rotated video and incorrectly mirrored selfie previews during calls.
- Group calls with only one other participant now use the regular call layout.
Update either through the application directly, or via Storeman/OpenRepos.
Your post doesn’t belong here, but rather there: Whatsapp importance in nowadays societies: keep or refuse?
Hi HtheB,
Thanks for the regular updates. I like it, runs smooth. But my calls still suffer from the rotated video call. In my case I see the other caller upside down. But with the other one (the pne i’m calling, everything is fine).
And is there a way to get more chathistory? On the android version it goes almost two years back. On Whatsup only a week, or sometimes a month.
Thanks!
@Thefriendlyfiend as a workaround, you can rotate your own camera by using the “…” MORE button, there’s a rotation button that shows how much degrees you’ve rotated your own camera. That way, you can rotate your own phone, and correct it by using the rotate button for the other person.
(your local view will not rotate but it will be for the other parties)
I know it’s not the solution, but at least a workaround that could work.
I’ll take a look at the chat history function if it’s possible to add a button that could load more history
I will give it a try!
No journal yet but it seems that QSGRenderThread causes the high CPU of lipstick. I deinstalled WhatsUp reinstalled it (1.3.0) and some time journal behaved normal but suddenly lipstick (QSGRenderThread) run “out of bounds”. (SFOS 5.2.0.18;WU 1.3.0; JP2)
whatsupd is still high with CPU from about 1-3.5 (5)%
in comparison:
Whisperfish 0.0%
Piirit 0.0%
Thank you for implementing group pinning for those in a community, but it doesn’t seem to actually pin a group in a community alongside the pinned groups outside of any community.
@dumol that’s because you didn’t enable it in the settings…
Thanks! A bit counterintuitive to have pinning work by default only inside a community, but can understand the logic behind it.
WhatsUp 1.4.0
New features
- Export conversations and group chats as TXT, HTML, CSV or JSON, with optional downloaded media.
- Load more older messages from your main phone.
- Turn off read confirmations completely.
- Choose when to confirm that you’ve listened to a voice message.
- See when someone has listened to your sent voice messages.
- View message information, including delivery, read, listened and deletion times where available.
- More compact message menus with actions side by side.
- Choose whether profile status text follows the header or is centered.
- An icon beside Connected shows when Auto-reply is enabled.
Fixes
- Bold, italic and other formatting now appear correctly in chat-list and cover previews.
- Incoming typing indicators work even when your own typing indicator is disabled.
- Contact initials no longer include punctuation or symbols.
- Errors appear as warning popups instead of taking up space on the page.
- Community groups no longer briefly appear as ordinary groups during startup.
@broncheolus WhatsUp should now show as “app” in lighthouse too since the 1.4.0 update
It does, indeed!
(20c)
