This does not make sense. It would make the concept of stop releases obsolete. Take a look
Releases | Sailfish OS Documentation and Updating Sailfish OS | Sailfish OS Documentation
@olf is wrong, everybody must install each stop release
the links you attached are exact and correct
for others who are confused:
in short: the outdated device must be updated in this way: from STOP ( 4.4.0.72) to STOP (4.5.0.25) to STOP (4.6.0.15) and finally to recent release (5.0.0.55 or to the next stop in the line what will be released in the future) …complete version history is here: Releases | Sailfish OS Documentation each stop release is marked as bold
next stop version in line is also clearly described in release notes for example [Release notes] Sauna 4.6.0.11 :
Stop release
4.6.0.15 is a stop-release.
Now that I have put the SIM card in the slot 2 during the duplicate, the mobile data also go with Android
Gets an error on my 10III, that the update did not succeeded.
Here after the android support not working.
After running version --dup, the phone is working again with version 4.16.0.15
I have updated both my C2s. On the second phone, mobile data doesn’t work in Android apps and I can’t send SMS. The only difference from the working phone is a different service provider and VoLTE is not enabled.
Dim…hmm… i took off Display–Adjust automatic brightness and it came a bit bright
I restored backup which was made before updating to 5.0.
Backup is 4.6 but when I check Xperia 10 lll has still 5.0.
Phone is useless because sms is not working.
With the Xperia 10 II, SMS sending also does not work
Congstar (Telekom Germany) VOLTE is not activated
I have the same issue
oh sorry, Congstar (Telekom Germany) VOLTE is not activated
I have a suspicion that this bug may also perhaps be telco dependent. Here in the UK on my 10 iii on ‘EE’ I’ve had this issue across many recent SFOS releases (though not so far on 5.0.0.55 - but it has only been a day on this release!), but on my XA2 Plus on ‘3’ I’ve never had this issue. When I tried, a while back, swapping SIMs between the phones, the non-connectivity problem followed the SIM. I appreciate these are 2 different phones, but when I took my XA2 abroad to Portugal last year and connected through a different telco, the problem appeared on this phone as well, whereas it was fine in the UK. Maybe this explains why some people have this issue and others don’t?
Hello,
my update went well (XA2), however after the update one of my two sim cards is not recognized any more. It uses the net of 1&1 Drillisch in Germany. The sim slot is not affected. I can switch the sim cards without a problem. After reboot there is a notification “Sim Card ist nicht eingerichtet” (Sim Card is not set up). Should I issue a bug report or are there any hints, how to solve the problem. I did try:
devel-su
systemctl stop ofono
rm -rf /var/lib/ofono/*
reboot
but it didnt help. I can provide ofono logs it that helps.
Did you try to disable and reenable one SIM manually?
Something like that I experience on C2 from the start (not yet on 5.0.0.55) and I strongly suspect enabled PIN on startup. Didn’t try to turn it of yet.
Unfortunately, that doesn’t help. In settings, I enabled Enter PIN, I rebooted, nothing changed, I removed the sim manually, rebooted, turned sim into the phone, rebooted again. It asks for the Pin, I can enter, but Sim still shows as unregistered in settings (mobile connections)
Question to the 10V experts… Is the battery consumption so catastrophic with you (even in idle mode)…?
It did succeed me to upgrade to 5.0.0.55.
I do not know if the following was the reason why I was able to upgrade, but anyway that was what I did.
1: Turned off the android support and also that the android must not startup when restarting the phone.
2: Restarted the phone.
3:Before doing anything on the phone, I began to upgrade the phone.
This time there was no issue upgrading the phone.
I have also the issue with the sms sending. I have a 10III and with the OS 4.6.0.15 I had the sending issue when the VoLTE was active. Now in 5.0.0.55 I have the issue also when the VoLTE is not active. ![]()
With what I have found out, there is 3 ways to “solve” the sms issue.
1: Flashing the 4.6.0.15 on the phone again. According what is installed on the phone this can take a long time.
2: In my case it is possible to receive sms, that’s good, so when sending it is possible for me to send using mms. So the person you are sending mms to is thinking why pictures every time.
3: I have notice, when the settings under the network mode is changed to 3G it is possible to send sms.
Hopefully the issue will be solved with the next update. Or, is there anyone who have a fix when knowing the above.
Sending SMS on Xperia 10ii is only possible here (also o2 in germany), when I switch to 2G. Taking of VoLTE ist not enough anymore.
On my X10III mobile internet works for Android-Apps, after using it once with native app. Before I use it with native app, it is not working with android app.
