Installed the update to 4.6 on XA2, reboot. Seemed to work fine, but hold on it is not connecting to the network. The option is not even in settings to connect. Reboot device. And now the gui is not coming up, rendering the device useless. Guess the end of the line for meâŚ
Actual I switched my daily driver because daily use of SFOS is full of Ooms, crashes and other stuff. I hope that this os will go further and there is a chance to switch back.
Android podcast applications are a mess. So why not do further work on podqast on SFOS (or mobile linuxes)?
I may have stopped mine with trying to open an Android app while AppSupport was still starting. It stopped and then on second try the AppSupport started ok. Xperia 10 ii.
In my case on 10III, update failed. After it said that at least 10000 packages have to be removed in order to install it properly, which of course I ignored, at the end of the update it said that update is not possible, try it later. The phone doesnât boot anymore, or at least it says to introduce rhe security pin and afterwards is the display doesnât turn on anymore. Strange is that the fingerprint vibrates, but thatâs it. Good that I have a reliable iOS with me otherwise I would have been lost.
Does someone else experience this? I have now been removing apps & libraries installed from chum & storeman but still the sfos update screen is showing a lot of conflicting packages. From OpenRepos it still shows me sailfish-components-webview-jb53103 from rubdos as installed, but it seems it is just some link as the actual installed package seems to be the official one from Jolla.
Attached a picture of the update view, how could I debug this issue or has someone been able to update successfully with these conflicting packages?
I canât see why it wouldnât be the right place to expect such information, if everything else concerning that very OS release has been posted here (including information about introducing support for the 10 IV and V), and - please correct me if I am wrong - if the event is supposed to mainly cover the introduction of that âAIâ thing.
Yeah RightâŚlike it will change something. Update process should be the foundation. If it fails should rollback. If that basic function is not working what shall I expect from functionality? History of Sailfish releases, the stable ones, prove you wrong. It is kind of perpetual beta software.
