Ouch. If you go the reflash route, there is not a downloadable 5.1 image yet. But you can go back to 5.0 and attempt the OTA update again to see if the problem reappears
Sometimes it takes time after boot. Or several reboots are necessary.
after update to 5.1.0.8, 5.1.0.10 email account with domain “mail.ru’ stopped work, but few other email domains work. I try recreate accounts: “mail.ru” doesn’t work.
p.s. purchase in jolla store stopped work with “mail.ru” domain few years ago
I don’t think so ! There are issues with Yahoo also, and they are due to authentication issues, XOAUTH2 not being supported.
Read this thread before posting. There are technical issues discussed before.
There doesn’t seem to be any updates relating to email or account setup in the changelog from post 1: Changelog_from_5.1.0.7_to_5.1.0.10.md
@ExTechOp I also have the tone out screen set at 30 secs and noticed the same. It managed to do all kinds of bad things before I realised it never blanked not even from phone call with head proximity, so my ear did a lot of deleting etc, not to mention the pocket calling/texting the selection … Setting the value “lpm” for powerkey-blanking again at least make it “blank” on press but not in the way that device lock setting “lock on blank” can kick in as before so it never locks with that setting now. I had to set device lock to “lock 1 minute”, but that is way too long compared to previously working usecase press the powerkey button and the device is locked immediately.
i have 2 email account from “mail.ru” service with 2 different domains. domain “mail.ru” no longer work, but “internet.ru” work. this domains doesn’t have some differences in protocol, etc. only name
about Russophobia:
few years ago (~2017 - 2019) I send request wia email to tech support from “mail.ru” account. they doesn’t answer me
New set-up on 10V only worked when I also filled the Calender Path. In my case “/dav/calendars/username/” that caused two overlaying error messages with a spinning circle but after restart of the Settings app, the account was working, but the Calendar Path field empty again. weird but working for me on both phones
I recieved perfect care from zendesk last year with a @mail.ru email.
we talk about jolla, not about zendesk
Remove and readd the account, it’ll work again.
I try it with 5.1.0.8 and 5.1.0.10 versions few times.I try it via mobile internet, wifi and 2 vpn via wifi.
2 others email account doesnt have troubles, only “mail.ru” domain
Let’s not get paranoid, and let’s debug this issue.
Can you trigger a sync and then get the log from the journal ?
devel-su journalctl -ar
PM it to me or post it here, we can see what’s wrong.
Jolla’s zendesk support.
ok. I try add account without verify. this log after try sync
[defaultuser@Xperia10III ~]$ devel-su journalctl -ar
Password:
– Logs begin at Sun 2026-06-07 00:02:26 MSK, end at Sun 2026-06-07 00:05:35 MSK. –
июн 07 00:05:35 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=240, batt_id_ohm=150
00
июн 07 00:05:35 Xperia10III kernel: pm7250b_charger: typec_or_rid_detection_change_irq_han
dler: IRQ: typec-or-rid-detect-change
июн 07 00:05:35 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=239, batt_id_ohm=150
00
00
июн 07 00:05:34 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=240, batt_id_ohm=150
00
июн 07 00:05:34 Xperia10III kernel: pm7250b_charger: typec_or_rid_detection_change_irq_han
00
июн 07 00:05:34 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=238, batt_id_ohm=150
00
июн 07 00:05:16 Xperia10III booster-qt5[4669]: *** signal=17 pid=4669
июн 07 00:05:12 Xperia10III kernel: [schedu][0x2f26bbbe9c][21:05:12.568621] wlan: [5084:I:
OSIF] vdev 0, scan id 41103 type COMPLETED(1) reason COMPLETED(1) scan found 7 bss
июн 07 00:05:08 Xperia10III kernel: [schedu][0x2f21b9fd7b][21:05:08.193291] wlan: [5084:I:
OSIF] scan start scan id 41103
июн 07 00:04:59 Xperia10III mce[1131]: modules/battery-udev.c: mce
bat_update(): battery_level : 27 → 26
июн 07 00:04:59 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=239, batt_id_ohm=150
00
июн 07 00:04:52 Xperia10III kernel: [schedu][0x2f102849c8][21:04:52.840139] wlan: [5084:I:
OSIF] vdev 0, scan id 41102 type COMPLETED(1) reason COMPLETED(1) scan found 12 bss
июн 07 00:04:48 Xperia10III kernel: [schedu][0x2f0ad6e088][21:04:48.192879] wlan: [5084:I:
OSIF] scan start scan id 41102
июн 07 00:04:43 Xperia10III kernel: [schedu][0x2f05fd75d6][21:04:43.955223] wlan: [5084:I:
OSIF] vdev 0, scan id 41101 type COMPLETED(1) reason COMPLETED(1) scan found 10 bss
июн 07 00:04:40 Xperia10III [5116]: [W] unknown:0 - “jolla-signon-
ui: CredentialsNeedUpdate now true. From: messageserver. Notification currently exists:
true”
июн 07 00:04:40 Xperia10III [4720]: [D] unknown:0 - Action completed 463856467969 result f
ailure
июн 07 00:04:40 Xperia10III [4720]: [D] unknown:0 - Invalidate credentials “imap4” from a
ccount 42
июн 07 00:04:40 Xperia10III [4720]: [D] unknown:0 - “1” RECV: a002 NO [AUTHENTICATIONFAILE
D] OAuth2 Access token is invalid or expired. Refresh the token or re-authenticate to upda
te the token
июн 07 00:04:39 Xperia10III [4720]: [D] unknown:0 - “1” SEND a002 AUTHENTICATE XOAUTH2
–More–
Did you add in your mail.ru account a specific password for a third party app?
Security of mail.ru is made so that it requires you to set a specific password for a third party imap login
yes, im recreate pass 2 times
I had the same problem installing from Storeman(?) and OpenRepos. I eventually succeeded by installing from GitHub - here is the direct link ( https://github.com/sailfishos-chum/sailfishos-chum-gui-installer/releases/download/1%2F0.6.9/sailfishos-chum-gui-installer-0.6.9-1.noarch.rpm )
