[RELEASE] keepass-kbd: your KeePass passwords and OTP codes, right inside the keyboard
Hello everyone,
I would like to share keepass-kbd, a keyboard-integrated password and OTP manager for Sailfish OS. Its main idea is simple: you manage your passwords and OTP codes from inside the keyboard itself, without ever leaving the app you are using. You can fill login fields in native apps and in AppSupport (Android) apps alike, and nothing goes through the clipboard.
Repository and releases: GitHub - solboki/keepass-kbd: KeePass password keyboard for Sailfish OS — fill, generate and save logins from your .kdbx database · GitHub
What it does
Fills credentials where you type. When you reach a login screen, you open keepass-kbd from the keyboard, pick the entry and insert the username, the password or the OTP code directly into the field. No copy and paste, no app switching, nothing left in the clipboard.
Guesses the context when paired with FUTO Keyboard. Combined with HtheB’s excellent FUTO Keyboard for Sailfish OS, it can work out what the field expects and suggest the username, the password or the OTP code accordingly.
Generates and saves passwords. When you create a new account, you can generate a strong password and store it in your database on the spot.
Adds new OTP entries three ways. You can type the secret key manually, scan a QR code with the camera, or read it from a screenshot. The screenshot option is handy when the QR code is displayed on the phone itself.
Works with one database or two. You can keep everything in a single KeePass database, or keep passwords and OTP secrets in two separate databases if you prefer not to put all your eggs in one basket. Databases are protected by a master password, a key file, or both.
How it was made
I am not a developer but an advanced user. When I got my Jolla Phone 2026, I decided to replace my iPhone 15 Pro Max immediately and completely. Since then, I have been trying to recover all my everyday phone habits, and when I find that a native app is missing, I use vibe coding to fill the gap.
keepass-kbd was coded by Claude Opus 5.5, based on my precise design specifications and, above all, on systematic real-world testing of every feature across many native and Android apps. I use it every day, and it has given me back the reflexes I had on my previous phone.
I publish my releases and source code to help people in the same situation as me, and also so that real developers can review them, criticise them or reuse some of the ideas.
Testing and feedback
I have only been able to test it on my Jolla Phone 2026 running Sailfish OS 5.2.0.22. I would be very glad to hear about your experience on other devices or versions, whether it works well or not. Issues and pull requests on GitHub are of course welcome.
As with any password tool, and all the more so for a project that has not been through a security audit, please keep a backup of your databases before you start.
Thank you for reading, and happy testing!
Will it be in OpenRepos or chum or something?
It will be on OpenRepos as soon as OpenRepos will work again. For Chum, maybe, but I must understand how Chum works before. You can download the app here : Releases · solboki/keepass-kbd · GitHub
