[RELEASE] FreeSailWallet - tickets, boarding passes and loyalty cards for Sailfish OS
Hey!
I’ve made a native app for SailfishOS that can parse through .pkpass files (Apple Wallet).
You can also add your own custom passes manually if you feel like doing so.
You can also archive the passes that you don’t use anymore.
Source code and download
You can find the source code on GitHub, code is licensed under GPLv3 and you are free to translate, edit, fork, change, modify, delete, eat and dance with the code.
I’m happy to take in suggestions, issues and pull requests. Download link is in the README.md file
Screenshots
The app is fully open source so anyone can audit, change and improve it - it stores very sensitive data and I believe no-one should be trusted to handle all of your boarding passes (that often contain reservation code that in turns allows you to modify your booking possibly leading to loss of money).
Alternative is a strong word…
What I like most in this case (except the source obviously and the actual reason you made it on the fly) is the fact that I can read the short and accurate description without getting an aneurysm like every time I read LLM descriptions.
Thank you!
I spent more than 14 days developing SailWallet, because there was no other usable option on the Jolla Phone. Now someone has stolen my application and broken my licence, and some of you are celebrating this theft.
Almost the entire user interface is a copy of my files from version 1.1.0: 18 QML and JS files are byte-for-byte identical and 12 more are only lightly modified. My licence file was replaced with the GPLv3 text and my copyright notice was removed.
Most of you probably didn’t know this, because the release post doesn’t mention SailWallet at all. I’m asking the author to remove my files from the repository and stop distributing the RPMs built from them.
Thank you for showing me how much respect some people in the community have for other people’s work, and how lovely some members of the community can be. Sure, I’m much more motivated now, and everyone will be much happier.
Even tho I’m not a fan of the closed source and license handling of @jaroslavm, I’ve checked his claims, and they seem valid. Very disappointing move by @mrcyjanek - if there is no really good explanation for this. Which i doubt.
We, as a community, should be better than this. Stealing other peoples work, especially without attribution, and while ignoring their set rules on how their work is to be used, is a no-go.
Of SailWallet’s 32 QML/JS files:
  • 18 are byte-for-byte identical in the repo
  • 12 are lightly modified (often just the rename)
  • and 2 are substantially rewritten.
The original licence file (“Copyright (c) 2026 Jaroslav Macušík. All rights reserved.”, no modification or derivative works allowed) was replaced with the GPLv3 text, and I found no credit to SailWallet.
The backend is most probably"original"/re-implemented, tho, since SailWallet is not source-available.
Anyone can reproduce this: unpack the RPM and run cmp/diff on usr/share/harbour-sailwallet/qml/ against the repo’s qml/ directory.
While closed source is cancer, if it’s straight up using the QML pages from the closed source app, then that would be a license violation.
License violation or not, it is not fair play to use other’s work without, at least talking to them before. But this seemed to become an opinion instead of an usual practice (talking, asking…).
It’s mine, anyway.
Well, if it’s open source software, you can do whatever you want with the software (within the requirements of the license). But in this case, it’s not open. The license is very simple and straightforward too, so it’s not like it’s unclear. The QML has to be removed from the repository and something new created from scratch.
I agree, you are formally right.
But delicateness is like oil.
Also true. People need to play nice. Sometimes people don’t play nice.
Sorry, no celebrating. There was no knowledge about it that is stolen and I haven’t checked because I thought there is no need to (llm work in one night I guessed). I appreciate your work and effort. Yes, open source would fit better to me but you made a choice and this is ok.
If the code was stolen than this is not the way we go here regularly. So keep up.
@jaroslavm I’ve removed all of the code copied over, and added explicit, license screen that mentions SailWallet and you and requires user to accept the license in order to continue.
@pentti
That was wrong on my end - and I’m really sorry, I did extract the QML files and created (well adapted a long unmaintained side project of mine) written in Go to serve the same API calls, with modifications on top.
This is restored, the license is now shown above the GPL notice.
Old RPM and source code distribution is removed, instead I distribute the .rpm (as permitted in the license) together with a set of patches (GPL licensed) and configure them to use my Go backend on install time.
There wasn’t much thinking or planning involved on my end, I was just happy that I can stop using my vibecoded flutter app and use some beautiful QML UI that @jaroslavm made.
I’ve force-pushed the repo to remove old distribution of QML files, and updated the RPM instead.
I’m sorry and If there is anything else that I can change/edit please let me know @jaroslavm.
Thank you, you did right with your corrective measures.
That being said, I think an original, own UI (and most probably name) would still be the way to go.
This post will probably be very long, for which I apologize in advance, and of course nobody is forced to read it.
@mrcyjanek: I really appreciate that you apologized. It certainly takes a lot of courage, and I personally know how hard it is to say sorry. Thank you.
Distributing the original .rpm, as you do now, is fine under the license, but modifying it afterwards, even after the app is installed, still goes against the license terms.
As @pentti already suggested, it would be best if you renamed the app and used only what you created yourself.
@projectmoon: I have a similar view of closed source, but nothing is black and white. Many amazing things would never have happened if they had to be open source. To me, the biggest problem with open source projects - thousands of forks that get abandoned after a few low-quality commits.
Have you considered that a large part of the Jolla Phone is closed source? The 5G modem firmware, the Wi-Fi firmware, parts of Sailfish OS itself, and more…
Trust me, the more popular Sailfish OS and the Jolla Phone become, the more closed-source apps there will be.
Also, the fact that I kept the app closed source doesn’t necessarily mean it has to stay that way forever. But right now, I’m very glad I did, and I’m convinced it was the right decision.
Having the source code available is not automatically a guarantee of quality and security. It’s not only about what is in the code, but also about what isn’t there, or what might be missing. That’s why reviewing source code requires deep knowledge of the wider context as well: how things actually work, and the other libraries the project depends on. Have you guys ever heard about that xz utils fiasco?
@pentti: Thank you so much for your reactions/responses and basically for guiding this discussion. I have a feeling that you are one of the good guys.
I got a question in a private message about whether I used AI. Of course I used AI, like almost everyone else. I have never claimed otherwise, and I have never denied it. If you have the right tools and you know how to use them, they will hugely boost your productivity. Otherwise, developing my app would take months.
Of course, I can see how everyone is trying to vibe-code apps, and because so many of them are of poor quality, people are starting to get fed up. But when the tools are used by the right people who know how to use them, the result is fantastic.
I once heard a great comparison: anyone can walk into a building supply store, buy bricks and build a house. But what will that house look like if the person doesn’t know how it should be done and doesn’t know the right processes? It’s the same with developing apps.
I released my first mobile app exactly 10 years ago, for Windows Mobile at that time. The way apps were developed back then is very different from the way they are developed now.
The view that anything created with AI is automatically worthless is very wrong.
With SailWallet, my goal was to create a high-quality app. I spent more than 14 days developing it, testing it and thinking deeply about it.
A lot of my knowledge and ideas are involved in it. I also did my best to make it as safe as possible, paying attention to the little details. For example: what if the server returns a redirect instead of the .pkpass file? What if that redirect leads to an unencrypted HTTP website? What about cookies between redirects (for example, tracking cookies from URL shorteners)? They should not be stored or passed on. And so on… These little things are usually completely unknown to people who are not developers.
I’d also like to come back to a few of the changes @mrcyjanek made, for example removing the Add button from the card list page (main screen). I implemented exactly that functionality yesterday, planned to be released in version 1.2. But instead of removing the button, I added it as a switch in the app settings, so anyone who wants to hide the button can do so. Card signature verification is also planned.
Some of the other things I’m planning are listed under “Future plans (To-do)” in the original SailWallet thread.
And guys, do not hesitate to post your ideas and requests. I can’t promise they will all be implemented, but they will definitely be considered. I would also be very glad if you could help me with adding support for more card-issuing services (more details later).
And I also use AI for English translations, as I’m not very talented at languages.
This is my last post in this thread. Have a nice evening.
Well said, no notes, 10/10. Thank you for the feedback.
Funny thing, my first mobile app was for Windows Phone (but Version 7, which was way out of date 10 years ago), too. God, I miss that Interface.
Of course many parts of the phone are closed. This is a general problem with hardware manufacturing today. But we shouldn’t let perfect be the enemy of good. My personal laptop runs the Linux-libre kernel and Coreboot. If I could reasonably do something similar on a phone that wasn’t low spec when it was released 6 years ago, you’d best believe I’d do it.
I’m someone who believes proprietary software is basically a human rights violation, so I don’t think further discussion down this road is productive or even really the point of this thread. Regardless of license choice, the license of your code was not respected (in a very big way), and that’s not OK. It’s your code and your right to decide the license.
Hopefully some day an upgrade to Qt6 will bring along with it the GPL, instead of Jolla attempting to secure a commercial Qt license or some other kind of exemption. That would solve this problem before it becomes a problem. Mandatory freedom for everybody!
I would think most people here are familiar with what happened with xzutils. Open or closed source is not a guarantee of security, no. But open source is definitely a guarantee that more people will be looking at the software, if it’s an important piece of software.
I disagree, it is the same as using patch manager against proprietary parts of SailfishOS - it is your device and it’s yours to use. EULA is not enforceable in this case.
This RPM does exactly that but to an app.
See in my view I am using only the bits I created (the patcher and backend) and code you created (the UI).
I dare to agree to disagree
So creating a project that’s literally impossible to contribute solves that exactly how? You literally rely on one person to be maintain the software forever and to not do a rugpull on all users.
I don’t think publishing the source affects that at all, well maybe except reducing the number of new projects in fawor of pull requests (like for example I had recently, instead of making a massive maps app and reinventing the wheel I could just open 30 lines of code change to add one dbus api to pure maps).
Have you considered that a large part of the Jolla Phone is closed source? The 5G modem firmware, the Wi-Fi firmware. parts of Sailfish OS itself, and more…
Do I really have to? Ehh.
Okay so part of that comes from the OEM and neither Jolla nor us have any say to do that and unfortunately debugging/changing parts of these is not as easy as normal user space app…
And as far as I can tell there are plenty of efforts to reverse engineer firmware/drivers too - not my thing tho, look at mainline linux for mobile or linux on macbooks in general.
Justifying publishing closed source just because there already is closed source software is (imo) like saying throwing trash out the street is fine because there’s already trash on the streets. (just an example, if someone is doing something bad it doesn’t justify doing bad things in general).
And I would be super happy for that to happen! If there would be an official [literally anything] app that is properly configured with sailjail then I’m very happy to utilize that.
But if there is an app that holds very sensitive data and has default internet access and is not published by a trusted entity. By just sending one request extra (moving the pkpass to a central server) some malicious entity could currently generate damages for thousands of euro for me at more or less any point in time. In addition to getting all of my details (including PESEL, Passport number, history of like 5 years of all my travels and events I went to) someone could get actual cash moneys of mine (since using my travel example - most of returned flights I have keep the balance in the booking code which is part of the ticket - you see where I’m going with this. Someone who could extract all pkpass from my device can literally rob me.
That’s why all pkpass files I own are stored in a terrible flutter app I made (and now in this project), because I can’t think of single app app that hands of money and information if compromised in an easier way.
Of course to be clear - I don’t imply you are malicious, I believe you are honest but at the same time I see 1000 ways someone in the process of sailwallet could cause me severe personal/financial/identity damage - it’s just a risk I can’t take.
This whole thing would not be the case if I could simply open a PR, instead of resorting to binary patching…
the exact same sentence can be said in inverse.
And how does closed source improve that?
Again, without moral questions of what your AI was trained one wether someone can copyright AI code…
I’m not sure how that changes anything wether the source is open or closed - you still get the same risks and keeping source closed just means even less people/AIs looked at it and even less time was given to review the code.
And as I said a potential bad actor who can hack/exploit the binary code in sailwallet can cause severe financial loses.
I do appreciate SailWallet and I do think I show that by using parts of it instead of prompting a model “yo do that”
I do agree, as I said very good project.
I’ve spent a few days on my backend too, and again I really appreciate your work.
I can think of very few cases where someone can control redirects of pkpass update but not the response itself… Considering that contents is literally two new lines away from headers in HTTP. Also pkpass needs to be signed so it’s not like update server can send malicious pass without full compromise. As for redirects: ApplePass (i think) could only give attacker the access to the pass (by fetching the update) which I think is fair to say they already have because they hacked the update server…
Anyway not the point. My point is how can I know? Do I sit with strace, gdb and mitmproxy watching over the app to see if it does what it says it does? How do I know if the app doesn’t have “if debugging” switches that change behavior? I do appreciate the effort you put into the app, and I don’t doubt it took some time. (and again, copying someone is the highest form of appreciation :wink: - I could never make a good QML design without spending literal weeks on it).
Have a nice day, I do hope for a reply tho.
@jaroslavm - how about accepting pull requests? You can still have a “all rights reserved” source available project that can get all benefits of being open source (most I guess) such as reproducible builds, PRs, or just use one of the open licenses that make it enforceable for everyone who builds upon your great foundation to contribute back!
I’m really serious I don’t think we need 4 wallet apps, 10 stores, 30 browsers and 700 youtube players. I would gladly submit PRs to existing software, especially that of good build quality - like yours.
@jaroslavm also if you want I can remove the entire project - regardless of any answers above if you want to. Just let me know.
Even tho your response is perfectly reasonable and i mostly agree and i don’t particularly care all that much about this app being closed source i still can’t help but nitpick here a bit.
Simply from logical point of view i still don’t see
Any valid explanation for why did you made the app close source and what is the benefit. Not saying that open-source should necessarily be a default or that you need a “valid” reason but looking at this explanation from somewhat a debating point of view, this argument lacks any point, impact or analysis. Doesn’t explain anything really.
Why would many amazing things never be created if they weren’t closed source ? Why are abandoned forks a problem for the original project and why would that be a problem for this app ? Closed source apps get abandoned too and then nobody can pick the development back up.
Why is parts of SailfishOS being closed source a good thing ? It’s actually something people complain about and as far as i know Jolla is doing it mostly because of their corporate and government customers and also because they are making money off the project of course.
Why is open source not being an automatic guarantee to security a problem and what added benefit does closed source give in this situation ? You mention xzutils fiasco which is the only concrete example here but that still wasn’t strictly a problem with open source it was more like social engineering problem. Could happen more easily in a company behind a closed source app. And the problem got partially resolved also because the source was available. Closed source isn’t any guarantee the code is safe either, makes hiding malicious code easier and process of discovering it harder. You can have situations like Solorigate too even tho that’s a bit different caliber.
